04-28-2015, 03:56 AM | #1 |
Rep 27
JB4 + catless DP's: Report back on gains with Dyno
Here are the gains i was able to achieve with JB4 and custom catless DownPipes...
+ 42 kw's (56 hp) at the wheels + 107 Nm's (79 ft. lb) at the wheels Car is non competition pack and running 95 octane pump fuel (no ethanol added). Also, i am at high altitude (approx. 1750m or 5750 ft above sea level). Am i correct in calculating the engine / crank output by adding approximate 5% correction factor for the altitude and a further 15% for drivetrain loss to get to 512 kw's (686 hp) and 982 Nm (725 ft. lb)? Are these number in-line with what should be expected? Car is feeling very strong and definite difference can be felt. And the sound from the dp's is AMAZING. All thoughts and comments welcome... |
04-28-2015, 06:37 AM | #2 |
Rep 2,176
The ECU is already correcting for altitude by increasing boost so take off that 5% and the drivetrain loss on our cars is more along the lines of 12% . Now you have a more realistic number , but most dynos are only useful really for showing the delta between mods not absolute numbers .
04-28-2015, 08:05 AM | #3 | |
Rep 27
04-28-2015, 09:19 AM | #4 | |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
On the whp to crank conversion for RWD cars.. (Whp or KW) /0.85 = crank number..12% -15% is a more or less standard and 18% - 20% for AWD.. (As far as I am aware Boss330 is good with these calculations..http://f10.m5post.com/forums/showthread.php?t=1086187) Hope you're having a lot of fun with your setup..
04-28-2015, 09:41 AM | #5 | ||
Rep 2,176
04-28-2015, 03:01 PM | #6 |
Rep 806
It does compensate for elevation and air density, but I don't think it is a perfect system. Taking air temps out of the equation I think there is still some power loss. Even at 2200 ft elevation, I will not achieve some of the faster numbers posted. I mean we are talking a few tenths and a few MPH, which to most people equates to zero.
05-01-2015, 09:53 AM | #7 |
Rep 643
Drives: BMW M5 F10
Garage List 2013 BMW M5 [0.00]
2011 Alpina B3S Bit ... [9.50] 2010 Alpina B3 Biturbo [10.00] 2009 Alpina B5S [10.00] |
Those are almost stock numbers man, check if your intake has a hole.. If so, buy the plugs and you should be at 600+ whp
05-01-2015, 10:15 AM | #8 |
Rep 1,805
At the wheel 423 kW is almost 498 kW at the crank with a 15% correction factor..
Stock M5 around 412 KW? http://en.m.wikipedia.org/wiki/BMW_M...0.93present.29 I think the number posted was at the wheel.
05-01-2015, 10:50 AM | #9 | |
Rep 643
Drives: BMW M5 F10
05-07-2015, 08:17 AM | #10 | |
Rep 27
In your opinion, is this gain lower than should be expected? |
05-07-2015, 09:15 AM | #11 | |
Rep 1,805
05-08-2015, 07:04 AM | #12 | ||
Rep 643
Drives: BMW M5 F10
The delta would be OK with Bms stage 1 only, but dps too, that's low in my eyes |
