      12-22-2018, 02:32 PM   #1
wheelpro
wheelpro's Avatar
Egypt
176
Drives: M5,F10,JB4,DP,CP,METH,SSP
After rebuild 1500 km
I removed my engine to inspect all parts and see if my project good or something wrong
Checked pistons, rod bearing, rods, sleeves , camshafts
All good
But I checked cylinders leakage test
With camshafts out
Share with you results
And i am confused thats normal or not
Cause i know fresh engine leakage normal from 5-10 % only
My piston rings gab first .060
And second .065
All cylinders Tdc
Mohamed kamal elkasaby
      12-22-2018, 03:16 PM   #2
SapphireM5
SapphireM5's Avatar
711
Is this all on the same bank the way you numbered them?
How did you break the engine in?
Boroscope of those cylinders?
      12-22-2018, 03:18 PM   #3
wheelpro
wheelpro's Avatar
Egypt
176
Yes all the same
Break in like normal steps
Or there is something wrong ?
      12-22-2018, 03:24 PM   #4
SapphireM5
SapphireM5's Avatar
711
Yes all the same
Anything above 20% - 30% usually indicates a problem or time for rebuild/tear down. I'm not being insulting just want to confirm:
- TDC for cylinder tested?
- Cams timed?
- what exactly was the break in procedure?
- could you hear air escaping while conducting the test? If so where?
60% leakage is pretty bad.
      12-22-2018, 03:42 PM   #5
wheelpro
wheelpro's Avatar
Egypt
176
Yes all the same
- Cams timed?
Tdc yes
Cams out of cylinders head
Break in like you stole it but not all time
And now only 1500 km
Air hearing from under pistons
But i cant feel air directly
Oil pan out too
      12-22-2018, 03:45 PM   #6
SapphireM5
SapphireM5's Avatar
711
Yes all the same
- Cams timed?
Tdc yes
Oil pan out too
If you are hearing air from under the pistons and in the oil pan then it's the rings. If the issue was in the head/valves you would hear the air coming out of the intake and exhaust.
What was the other side percentage?
      12-22-2018, 03:48 PM   #7
wheelpro
wheelpro's Avatar
Egypt
176
Yes all the same
- Cams timed?
Tdc yes
Oil pan out too
All cylinders the same
Only air hearing from oil pan
      12-22-2018, 04:08 PM   #8
SapphireM5
SapphireM5's Avatar
711
Yes all the same
- Cams timed?
Tdc yes
Oil pan out too
Yeah then the rings are allowing the air to pass.
Maybe ring gap or they didn't seal during break in.
Sorry buddy i know how hard you have been working to get her back up and running.
      12-22-2018, 04:18 PM   #9
wheelpro
wheelpro's Avatar
Egypt
176
Yes all the same
- Cams timed?
Tdc yes
Oil pan out too
But may be rings need more mileages to set ?
Its total seal brand
      12-22-2018, 04:26 PM   #10
SapphireM5
SapphireM5's Avatar
711
Yes all the same
- Cams timed?
Tdc yes
Oil pan out too
Hopefully someone who knows more than me will chime in, but I would think at 1500km those rings should be seated. We're the cylinders honed / machined during the rebuild?
      12-22-2018, 04:47 PM   #11
wheelpro
wheelpro's Avatar
Egypt
176
Yes all the same
- Cams timed?
Tdc yes
Oil pan out too
Dont forget
Engine cold
Cylinders head not torqued as well
My pressure 70 psi only
100psi target from 0-10 % leakage
70 psi = target 70- 60 leakage
Right or wrong ?
      12-22-2018, 05:48 PM   #12
SapphireM5
SapphireM5's Avatar
711
A cold engine will effect results. Usually you Zero out the gauge with the regulator before you connect to the line in the spark plug hole. Once you connect it gives you the percentage loss. Just want to confirm you did that.
      12-22-2018, 05:50 PM   #13
wheelpro
wheelpro's Avatar
Egypt
176
I will do this steps tomorrow
With updates
Thanks for your reply
      12-22-2018, 05:54 PM   #14
SapphireM5
SapphireM5's Avatar
711
With updates
I found a good video here for you, it will explain it better than I could lol
Good luck bud!
wheelpro176.00
      12-22-2018, 06:24 PM   #15
SapphireM5
SapphireM5's Avatar
711
Dont forget
Engine cold
Right or wrong ?
I missed this before, yes if you were introducing the air directly without Zeroing the gauge and you cranked it to 70 and the gauge on the right read 60 then yes that would be 10% loss if thats how you did it, which wouldnt be bad for a cold engine. But if thats how you did it.
wheelpro176.00
      12-23-2018, 02:39 PM   #16
Sales@RKautowerks
Sales@RKautowerks's Avatar
357
Drives: e92 m3
You're suppose to do this all with the engine warm for accurate results. I honestly don't know why you guys even went to the lengths you did to tear apart a good engine. All you've done is introduced issues now for no reason.
-R
      12-28-2018, 08:59 PM   #17
wheelpro
wheelpro's Avatar
Egypt
176
-R
Do you want to know why ?
Cause thats not normal
      12-28-2018, 09:15 PM   #18
SapphireM5
SapphireM5's Avatar
711
Rings bad?
      12-28-2018, 09:23 PM   #19
wheelpro
wheelpro's Avatar
Egypt
176
Rings bad?
All 8 cyl rings bad ?
Not normal ?
And i inspect them looks good
I have photo not clear but you can see too
      12-28-2018, 09:25 PM   #20
SapphireM5
SapphireM5's Avatar
711
Tough to see in the pictures, but does it
Look like oil is getting passed the rings?
      12-28-2018, 09:32 PM   #21
wheelpro
wheelpro's Avatar
Egypt
176
No oil
But i worried about leakage too
And engine like rich
      12-29-2018, 02:26 AM   #22
Dwaynos
Dwaynos's Avatar
Did you go back and do another leakdown after ensuring everything was sealed tight and zeroing the gauge?
