      03-02-2023, 08:16 PM   #1
zalikoo1
Drives: M5 F10
2012 BMW M5   [0.00]
crankshaft position sensor error please help
I really ask for help. I have a 2012 BMW M5, when turning the steering wheel to the left during a sharp acceleration, when the rear of the car blows to the right, (DRIFT) error 160020 crankshaft position sensor comes out, if you accelerate straight, or drift to the right there are no problems. checked all the grounds, replaced the crankshaft sensor, replaced the wires to the sensor from the engine control unit, replaced the engine control units, replaced all the ignition coils, replaced the flywheel, checked the fuel pump, turned off the ICM control unit, a lot of work was done, I don’t remember everything. BMW M5 F10 2012
      03-05-2023, 02:25 AM   #2
Don't think you'll get much help here mate.
      03-07-2023, 06:19 PM   #3
Black Panda
Nick
Black Panda's Avatar
Drives: 2013 BMW M5 Comp
Does the engine light come on? What is the exact codes your getting??
      03-07-2023, 06:21 PM   #4
Black Panda
Nick
Have you done a throttle relearn reset??
      03-07-2023, 06:27 PM   #5
zalikoo1
Drives: M5 F10
2012 BMW M5   [0.00]
if the stabilization is not turned off, the problem is not observed, if the rear axle of the car is put into the right skid, only then the error appears, the diagnostics shows the crankshaft position sensor, “the signal is not reliable” an oscilloscope was connected, interference appears on the signal wire of the crankshaft sensor
      03-07-2023, 06:29 PM   #6
Black Panda
Nick
The code is set when your car's primary computer—also known as the powertrain control module (PCM)—is unable to detect a signal from the crankshaft position sensor. Tcm sends signal to pcm. You could have a faulty tcm. Also it's a 2012. Is it tuned?? Have you tried disconnecting the pos and negative terminals on your battery and wrap them together and let it sit for an hour and then reconnect the battery
      03-07-2023, 06:34 PM   #7
Black Panda
Nick
You'd be surprised how tedious these cars are. Also check to make sure the vanos is good. Clean your Maf sensors on the intake pipes. Try anything I've asked.. lmk
      03-07-2023, 06:34 PM   #8
zalikoo1
Drives: M5 F10
2012 BMW M5   [0.00]
I didn’t quite understand what you mean, the transmission also falls into emergency mode, it also has a secondary error from the crankshaft position sensor
      03-07-2023, 06:36 PM   #9
zalikoo1
Drives: M5 F10
2012 BMW M5   [0.00]
I changed all 5 volt sensors
      03-07-2023, 06:36 PM   #10
Black Panda
Nick
Well my friend.. don't drive yourself nuts. I'd try a few more things and then take it to a reputable bmw mechanic if it still persists.. not worth driving yourself nuts
      03-07-2023, 06:37 PM   #11
zalikoo1
Drives: M5 F10
2012 BMW M5   [0.00]
this has been a problem for several years now
      03-07-2023, 06:37 PM   #12
Black Panda
Nick
I wish I was a mechanic and could be more helpful..IF ITS been that long of a time I'd take it to BMW
      03-07-2023, 06:41 PM   #13
Black Panda
Nick
Do a throttle relearn procedure...
      03-07-2023, 06:45 PM   #14
Black Panda
Nick
Put car in ignition mode
Don't touch brake
Floor the accelerator and hold it for 5 seconds
Keep your foot on accelerator and shut car off
Wait 10 seconds and take foot off throttle
Don't touch anything and wait 2 minutes and start the car.then go drive it aggressively and see how it runs
      03-07-2023, 06:48 PM   #15
zalikoo1
Drives: M5 F10
2012 BMW M5   [0.00]
thanks i try
      03-07-2023, 07:45 PM   #16
Black Panda
Nick
thanks i try
I have a 2013 m5 and I was getting the powertrain code which would come and go..
I did a throttle adaptive reset and cleaned the maf sensors and made sure there was no leak anywhere on the intake and I haven't had a problem since. It's only been 200 miles but still no code. I know it's a different code then yours but sometimes with these bmws 1 little thing can cause shit to happen.. sometimes it's a simple stupid fix.
Lmk how it works
