      07-02-2017, 10:08 PM   #1
Stealth_Bomber
Drives: 2014 BMW 535 M Sport
Question Upgrade the Xeon headlight with Osram modules?
Someone told me i can get more light output on the hid's with osram units due to them being German spec or something same goes for fogs. Any truth to this has anyone gotten more light on the road some how. Mine is a 2014 and the light output seems blah compared to a 2017 loaner i just used recently yes it was Hids as well non led.
      07-04-2017, 02:21 PM   #2
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
HID bulbs do indeed degrade over time. Imo you have two options. If you are looking for max output and you don't mind a little yellow in your light go with osram night breakers. If you want a pure white light without loosing any output over an oem set go osram cbi.
Make sure you buy from a legitimate source as there are a lot of fakes out there. Good luck!
      07-09-2017, 04:03 AM   #3
Stealth_Bomber
Ok cool what legit source do you recommend?
      12-23-2017, 04:03 PM   #4
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
^This. The CBI work great. They are a bit bluish on startup but as soon as they warm up they're a nice white.
You could try TheRetrofitSource or perhaps a used set from a board member.
      12-25-2017, 02:18 PM   #5
BMWAUDIO
Drives: F90 M5 Frozen Gray , 997 C4S
is there an upgrade available for Led headlight ?
      12-29-2017, 01:56 AM   #6
Aaron@Autosource
98
Drives: F110/F22
Not as far as I'm aware-
