      07-15-2011, 04:47 PM   #1
halkordy89
Drives: '07 e90 335i
do the m5s have the same engines as in the 550s??
I'm just curious to know if they do, n where the only difference is that the the m5s are merely tuned differently. Thanks
      07-16-2011, 01:13 AM   #2
wisesoul
Savoir Faire
wisesoul's Avatar
Philippines
74
Drives: 2013 BMW M5
Different exhaust manifold, twin scroll turbos, not single scroll turbos like the N63, camshafts designed for higher lift, bigger oil coolers and intercoolers, higher compression ratio leads me to believe that the pistons may be stronger.
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel
Sold:E46 323i
      07-16-2011, 05:10 AM   #3
Powerslide
Drives: 2018 F80 ZCP
I could be wrong but I believe the N63 in 550i and S63tu in M5 may not share much more than the engine block and displacement of 4.4l -- interesting question though...
      07-18-2011, 02:40 PM   #4
halkordy89
Thanks for your help. I had an argument with a friend n was just curious
      08-05-2011, 06:42 PM   #5
E90Fleet
South Africa
1312
Con rods, Cylinder head gaskets and oil fill cap are shared
Confirmed
