      02-15-2018, 09:12 PM   #1
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
SSP Spec-Z Clutch
With the levels of torque the car was making and the ratings for the Spec-R clutch (around 900 ft-lbs crank or 750 ft-lbs at the wheel) I decided to contact Kris @ SSP and inquire about what he may have to support the 1000ft-lbs at the wheel or 1200ft-lbs at the crank levels. I was surprised the Spec-R (new clutch) held to around 900 ft-lbs at the wheels but couldn't hold much power beyond that. At the 750 ft-lb at the wheels range they are perfect as advertised! Also shows the capability of a product when it performs beyond its advertised specifications!
So, back to the issue at hand...turns out Kris has a Spec-Z version (20-plate). Kudos to Kris to get that turned very quickly and shipped. With a core housing Kris sent the assembled housing including baskets etc. so the install process just involves removing the DCT and swapping the housing assembly.
Finished up the install at Trinity Autosports (Joe did the clutch on my previous car as well) and now in the break-in process.
Initial observations - shifts and feels like stock with no apparent difference to the Spec-R. Keep in mind I am staying under 3-4K RPM and little to partial load only. The adaptations worked the first time. I will re-adapt again once break-in is complete.
Now that the CSF/Pure IC's are installed as well, will plan on another dyno to see what kind of power the car is capable of. Now that we know the clutch can hold its time to unleash even more boost!
Stay tuned...
      02-16-2018, 06:14 AM   #2
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
Staying tuned
      02-16-2018, 12:54 PM   #3
JK-M5
JK-M5's Avatar
Drives: MBB F90 M5
you get my message dude regarding the clutch?
      02-16-2018, 02:26 PM   #4
bm5bullit
bm5bullit's Avatar
Drives: 2021 BMW M340i
Great to hear that you will be able to use all of your power.
2021 M340i
2020 X3 M40i - her car
      02-16-2018, 02:30 PM   #5
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Subscribed.
      02-16-2018, 03:15 PM   #6
allmotor_2000
1087
Yup - and replied!
      02-17-2018, 02:18 AM   #7
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
waiting for dyno results,, good luck
      02-18-2018, 01:14 PM   #8
JK-M5
JK-M5's Avatar
Drives: MBB F90 M5
Originally Posted by allmotor_2000 View Post
Yup - and replied!
Nothing in my inbox lol.
      02-18-2018, 06:26 PM   #9
allmotor_2000
1087
Sorry - I replied to like 25 people and pretty sure to everyone who PM’d or contacted me via IG. Must have missed you somehow.
      02-18-2018, 11:17 PM   #10
allmotor_2000
1087
So break-in completed. I decided to hook up ISTA-D and do another clutch teach-in along with all the DCT adaptations.
Did a quick drive at 22psi and felt good. Will put some race fuel in and try higher boost later this week.
The ‘bite’ seems harder upon shifts. Intimately I need the Spec-Z to hold around 1000+ ft-lbs torque at the wheels so let’s see how it does!
Sorry far so good...
      02-19-2018, 11:37 AM   #11
steeve13m
Hows the up-shifting and down-shifting....I heard there's a lag when you go with big number of plates?
      02-19-2018, 11:42 AM   #12
allmotor_2000
1087
It’s the same - why would there be a difference? The clutch doesn’t know if it was up or down? It is pre-engaged depending on the situation. IF you are accelerating and then suddenly decide to downshift there may be a delay but not if it’s in any predictable flow
      02-19-2018, 03:27 PM   #13
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Awesome! Can't wait to see what you put down
