04-08-2017, 09:20 PM | #1 |
Dictator for Life
343
Rep 560
F10 M5 MT shifting
Ive had my F10 for almost 6 months now and I never once thought I made a mistake grabbing it from the dealer.
I just have a question for those with a MT F10, do you experience a little jerk/push when you are about to release the clutch? Its like you cannot balance the clutch release and gas on 1st and 2nd gear, and after that, you are able to balance it. I have 3 other MT cars and my M5 is I think the bumpiest to drive. Anybody with thesame problem?
03 e39M5 Imola Red-Tubi Exhaust/GROMAudio
16 F10 M5JavaGrun/MT/CP/CCB/B&O/ReaRDVD 23G82M4SignalGrun/MT/CCB/CarbonBuckets 09 Ferrari SCUDERIA Rosso Corsa 23CayenneGTSCoupe |
04-10-2017, 08:03 AM | #2 |
Rep 66
Drives: 2023 530i X-Drive
thx,
I have not experienced this jerk/push to which you reference. My '16 M5 shifts are smooth as butter. Regards, Danny |
04-10-2017, 08:57 AM | #3 |
Rep 1,519
At first
Yes u do. Lol I thought it was me. But its normal. From stop Rolling i let clutch grab first gear before hitting gas let it roll. Then 2nd. I ket it grab also 3-6 i drive it. |
04-12-2017, 10:38 AM | #4 |
Rep 252
I've never experienced this. That being said, if your car is relatively low miles (<5K) then maybe the clutch isn't broken in yet? The clutch has to be really strong for 550+ hp in a 4300 lb car.
04-20-2017, 07:36 PM | #7 | |
Dictator for Life
343
Rep 560
04-20-2017, 07:38 PM | #8 | |
Dictator for Life
343
Rep 560
i think it is just the way it is. How different this tranny is from my Pcar TT or Fcar. Love it in the hwy though.
04-20-2017, 07:39 PM | #9 |
Dictator for Life
343
Rep 560
Im at 4900 miles.
04-20-2017, 08:44 PM | #10 |
Rep 224
I would get it checked out... I very seldom experience the jerkiness and when I do it's my fault for not giving it enough gas. Mine drives pretty much like any other stick I had.
You must have some issue with the clutch. |
04-21-2017, 12:55 PM | #11 |
Rep 1,519
Maybe just need to get use to it. Lol
04-21-2017, 03:22 PM | #12 |
Rep 6,067
It's called TORQUE MONSTER lol
You have to get used to it. I had the same issue with M4 MT. Changed seat position and everything with no success... finally figured out the balance between clutch and gas will be achieved at lower position of clutch because of torque... Having said that you need more gas before releasing the clutch compare to other cars...let's say this was: releasing 1 cm clutch you have to depress 2 cm gas ...
04-21-2017, 06:18 PM | #13 |
Rep 224
My friend was driving my car around today. He couldn't get it smooth at all. lol and he comes from a viper. These m5s are tricky but once you get it then you got it.
04-21-2017, 09:33 PM | #14 |
Dictator for Life
343
Rep 560
I have 3 other manual cars, this is the jerkiest at first gear.
But I love this car. In fact, I am crazy enough, I might buy another one. I was lucky enough to get this with a comp pack with CCB.
16 F10 M5JavaGrun/MT/CP/CCB/B&O/ReaRDVD 23G82M4SignalGrun/MT/CCB/CarbonBuckets 09 Ferrari SCUDERIA Rosso Corsa 23CayenneGTSCoupe Last edited by thxbuff2001; 04-21-2017 at 09:55 PM.. |
04-21-2017, 10:02 PM | #15 |
Rep 6,067
Is your GT3 RS manual too?
04-22-2017, 08:58 AM | #17 |
Rep 224
Nice cars! Try this. Slowly let out the clutch, slow enough not to stall without adding any gas. Do this a few times and find out when the clutch engages. Eventually do it with adding the appropriate amount of gas. Should be smooth as silk
04-22-2017, 01:04 PM | #18 |
Rep 3,200
On the older M cars, like the e46 M3, there was a cdv. A clutch delay valve. Removing it allowed for much smoother shifting. It is attached to the clutch line. Maybe try and research if the the f10's have it. If so that will solve it.
You could also try a Mason Engineering clutch pedal too when you do the cdv delete, but again I'm not sure if he makes one for the f10 or if all BMW clutch pedals are the same. |
04-23-2017, 12:10 AM | #19 |
Rep 6,067
04-24-2017, 08:46 PM | #20 | |
Dictator for Life
343
Rep 560
I think the problem is the spring in the pedal. There is like a hump that springs back on release which is hard to stop. Do you guys experience this too? I think ive read there are people in the e90 m3 guys who removed the return spring and just left the inward spring. Is this possible too? |
04-24-2017, 08:51 PM | #21 | |
Dictator for Life
343
Rep 560
If I try to release it slowly and then on the depression/or hump maintain it there for a while(millisecond), then total release the clutch, you will have a smooth release but its hard to do, the the spring is so strong, you cannot resist all the time and will be tiring. Its hard to explain. Its going for its oil change this friday and I will let the tech test drive it.
04-24-2017, 09:23 PM | #22 |
Rep 224
I don't really have a strong return spring. See if the tech can stretch out the spring a bit?
Mines a 2013 with 30k on it. I do stutter sometimes out of 1st, more so than other cars but it's not abnormal. |
