      04-01-2014, 07:17 PM   #1
Mbmw5
Drives: 2013 M5
Vibration w/ new wheels and H&R springs
Going back to the shop tomorrow. Had new 21" forged wheels and springs installed. Have a vibration at higher speeds. Any thoughts out there???
      04-01-2014, 07:19 PM   #2
boots
Curve Thrasher
boots's Avatar
623
Make sure they did not strip any of your strut screws. Double check wheel balance first, then to the spring shop.
Country run
      04-01-2014, 08:03 PM   #3
Mbmw5
Drives: 2013 M5
Hey boots. I meant to post in wheel / tire section. If they stripped the bolt that would cause a vibration? I originally had a noise in the front driver side and brought it back as I found it while pulling out of the lot. They pulled the car in and made some adjustment to the front strut under the hood. Said the bolt was loose. That noise went away but now I have the vibration. They are going to put old wheels back on to eliminate if it's the wheels. Thanks for the feed back. Very much appreciated. Btw I have a top notch shop doing the work and have total confidence in them. Just frustrating.
      04-01-2014, 08:27 PM   #4
boots
Curve Thrasher
boots's Avatar
623
This happened to me. But they had to replace a couple parts. I knew I wasn't going crazy. So if yours was loose once I'm willing to bet it is stripped and cause your vibration. They can fix it though. Oh yea. Don't worry about the wrong section. I'm sure the moderator is getting ready to move this. He he
      04-02-2014, 02:25 PM   #5
HXS
Licensed Drug Dealer
HXS's Avatar
Most likely one of your front wheels aren't balanced.
      04-02-2014, 06:53 PM   #6
boots
Curve Thrasher
boots's Avatar
623
It can be either. This happen to mine
      04-02-2014, 10:31 PM   #7
hova00
hova00's Avatar
1191
Drives: G80 M3C
Same thing happened to me with aftermarket wheels it ended up being that the rim wasn't 100% hubcentric and needed hub centric rings to fix the problem but I went from a steering wheel shimmy at certain speeds to a super smooth ride. I didn't end up finding out that was the issue until 2 hunter road force balancings later that didn't fix the problem.
I suggest you measure the wheel to make sure it is hub centric.
      04-04-2014, 02:08 PM   #8
Timberwolf
Timberwolf's Avatar
196
Drives: People crazy
My Macht Schnell spacers vibrate over 80mph. Going to confirm this in the coming week. Did you use spacers by any chance?
991 Turbo
993 GT2 Outlaw
      04-08-2014, 07:02 AM   #9
dhirm5
Drives: 2014 M5 ZCP, 2014 X5 35d
My H&R spacers are buttery smooth through XXX mph. Spacers unless they're defective or improperly installed don't usually cause vibrations.
2009 Aston Martin DBS - Casino Royale Gray on Black (sold)
2014 M5 ZCP - Azurite Black over SSII Full (gone)
2009 M5 - Carbon Black over Sepang Full (gone - not forgotten)
2001 740i M-Sport - Carbon Black over Black (gone - not forgotten)
      04-08-2014, 03:06 PM   #10
boots
Curve Thrasher
boots's Avatar
623
What's the update
      04-08-2014, 04:23 PM   #11
Knight Commander
Sounds like shit manufacturing. Can't believe you paid money for that wheel when BMW supplied a better quality product from the factory.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
      04-09-2014, 08:34 PM   #12
Mbmw5
Drives: 2013 M5
So it ended up that the new H & R springs weren't the issue. I put the factory 20's back on and the car was smooth as silk. We had the front wheels checked with a dial indicator and they were out 30 thousandths. Working with velos they are cutting new fronts for me. The rears are ok as I also put the new ones on with the factory fronts to confirm. All was good even at 130mph. Velos is standing by their product. Will post pics once they are back on the car.
      04-09-2014, 08:37 PM   #13
Mbmw5
Drives: 2013 M5
No spacers. Also wheels are custom for the car so they mounted perfectly. Just frustrating when you spend 5 k for wheels and have these issues. Velos is standing by their product though.
      04-09-2014, 08:42 PM   #14
Mbmw5
Drives: 2013 M5
Stealth, can't argue that fact. The 21's are beautiful though and classy. What good is it though if you sacrifice performance which I won't. I feel confident at this point though that I'll get the issue worked out.
      04-09-2014, 10:04 PM   #15
boots
Curve Thrasher
boots's Avatar
623
Glad you found the fix.
      04-10-2014, 09:02 PM   #16
Mbmw5
Drives: 2013 M5
Thanks boots. This is a grt forum with good people.
