02-19-2014, 02:33 PM | #1 |
Rep 1,809
Update - dyno'ed on Dynojet with new fuel
My car has charcoal filters removed and BMS piggyback. Nothing else
I do not have baseline numbers from dynojet only from mustang dyno. I was critical of BMS so on their advise I mixed 100 Octane with our shitty 91 Octane here in Cali. The original dyno I used is 60 miles away so I used a local shop that uses a Dynojet. I am not at all saying the gas made a difference, I am just posting my results from the dynojet which I am very happy with. 589.31 wheel hp and 548.38 wheel lb/ft. (using a correction of 15% as was recommended by dyno operator and several others that would make it 678 hp and 631 lb/ft at the crank) After mixing the fuels and running the car it did feel much stronger than I reported a couple days ago.
2024 Porsche 911 GTS Cabriolet
02-19-2014, 03:45 PM | #2 |
Rep 978
Data
Very, very nice and impressive results. What would be nicer would be some V-Box runs reflecting mid-range to upper level differences.
2021 M340i
02-19-2014, 04:03 PM | #3 |
Rep 1,809
Yes I need to get on the 1/4 mile run etc....
02-20-2014, 03:55 AM | #4 |
1989
Rep 9,498
Three Questions:
1/ How much are these Boxes?. 2/ How easy are they to fix and remove?. 3/ Any CEL ?
02-20-2014, 08:02 AM | #5 |
Curve Thrasher
623
Rep 3,773
Not knocking anything anything you did my brother, but using any number of a higher octane will net better results. I'm curious as to what yours will net using that same mustang you started with the addition of the higher grade fuel. Here in Houston we have 93.
Country run |
02-20-2014, 12:04 PM | #6 |
Rep 10,145
You do know that Dynojets read higher than Mustangs... unless the settings are adjusted. What you should do to get piece of mind is go back to the other dyno where you felt the numbers were inadequate. I know its 60 miles away but thats the only way you know if anything changed and even then you will dyno it on a different day with different conditions. If your butt dyno makes you smile than call it a day and crush the enemy on the roads!!!!
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
02-20-2014, 01:12 PM | #7 | |
Rep 1,809
02-20-2014, 01:24 PM | #8 |
Rep 1,809
I agree for sure. I will be retesting on that Mustang dyno in next few weeks. I will post the results.
02-20-2014, 01:32 PM | #9 |
Joint Chiefs of Staff
4907
Rep 115,980
These results look great especially for SAE correction! On the 91 octane what many do is just mix in a can of NOS race octane booster ($10 at WalMart) to 12-15 gallons of 91. It is supposed to make your 91 like 93 octane then. What the rest of the world gets.
Mike |
02-20-2014, 01:37 PM | #10 | |
Rep 1,809
02-20-2014, 02:45 PM | #11 | ||
Rep 2,176
02-20-2014, 03:13 PM | #12 | |
4907
Rep 115,980
Mike |
02-20-2014, 04:03 PM | #13 | ||
Rep 2,176
02-20-2014, 05:54 PM | #14 | |
4907
Rep 115,980
http://en.wikipedia.org/wiki/Methylc...se_tricarbonyl "The health hazards associated with manganese compounds emitted from vehicles operating on gasoline containing MMT have been debated for decades. In 1994 (reaffirmed in 1998, 2001 and 2010), Health Canada concluded that "airborne manganese resulting from the combustion of MMT in gasoline powered vehicles is not entering the Canadian environment in quantities or under conditions that may constitute a health risk"[19] and confirmed they were taking no action with respect to MMT. The 2003 NICNAS study ruled that the airborne concentrations of manganese as a result of car emissions from vehicles using fuel containing MMT posed no health hazard. Additional health studies, overseen by the US Environmental Protection Agency (EPA), have been conducted in order to explain the transport of manganese in the body. These studies, the most recent available, published by the Hamner Institutes for Health Sciences from 2007 through 2011 and submitted to the US Environmental Protection Agency (EPA) under the framework of the Clean Air Act, show that the body's natural mechanisms can handle a wide range of manganese intake, whether from inhalation or ingestion.[20] While these mechanisms can be overwhelmed if exposures to manganese are very high (as in the case of some occupational exposures), the testing confirms that the body can safely handle inhaled manganese at, and well above, levels observed when MMT is used in gasoline. The studies also indicate that MMT use is safe for the entire population including vulnerable groups such as infants and the elderly. Although the EPA will now formally review the research findings, the US Agency recommended this data as meeting the Clean Air Act's health study's requirements and objectives." |
02-20-2014, 06:13 PM | #15 | ||
Rep 2,176
Lets just agree that its cheap , reduces knock and turns shit orange and leave it at that . |
02-21-2014, 12:34 AM | #16 |
Rep 4,106
You should register for the Shift sector event this Sat
02-21-2014, 01:35 PM | #17 |
Rep 2,176
02-21-2014, 10:47 PM | #18 |
Rep 1,809
I know a bunch of guys going. I was supposed to go but cant make it...I will def make airstrip attack in april though....
