02-12-2015, 04:52 AM | #1 |
2nd to None!
42
Rep 296
Drives: M8 GC, M5 30Jahre, X6 50i
KW V3 and Dinan Sway Bar intsallation
Hi there,
Just got them install on my M5. Have some issue with the front Sway Bar installation. The installation is done by BMW. I was told by the technician that the supplied Dinan adjustable link is way too long to get the Front Sway Bar connected with the KW V3 Coilover with the Dinan recommended length on the adjustable link. Are the BMW Techincian doing something wrong in the installation??? The height of the KW V is set to the same height of a M5 CP ride height. Any idea whats happening?? Any tips will be a great help. Thank you. |
02-15-2015, 08:56 AM | #3 | |
Perennial PFC
336
Rep 1,274
KW V3 shock/BMW M5 shock
The BMW sway bar is bonded to its rubber bushing, so once it's mounted rotation of the bar is not possible to deal with the 1 3/8" difference in length. The Dinan bar should be movable, and with the adjustable link you should be able to make it work. I'll call KW tomorrow to see if they have a work around for my situation. Edit:Have the front fully assembled and the sway bar link bolt is about 3" above the attachment point on the KW V3 shock. Please ask your mechanic if yours is about that same distance. I'm sure others have installed the KW V3 with BMW sway bars, but I've assembled everything properly. It's almost impossible not to, I don't know what could be done to make this bolt up, frustrating. Edit 2:It's good to know that a professional mechanic might be as stupid as a home tinkerer. Perhaps your mechanic was looking at the install as I was, with the wheel at full droop on the lift. The sway bar won't line up in that situation. All it takes is to lift the wheel hub enough (compressing the shock) and the shock tab will be even with the sway bar link! I hate being stupid in public! Here's a second shot of what I was looking at. Last edited by Used2be; 02-16-2015 at 11:18 AM.. |
02-19-2015, 08:44 PM | #5 | |
Perennial PFC
336
Rep 1,274
I am really having to restrain myself from doing the catless downpipes with either the BR or AMS tune! So tempting, but I fear I will wait until after warranty is up. Too chicken to void warranty. |
02-19-2015, 08:55 PM | #6 |
Curve Thrasher
623
Rep 3,773
Glad you sorted it out. You won't void the warranty w dp. That mod yields some great power and sound. You can't go wrong. I get my ecu back from br next week and will post up a review. I can tell you it is the real deal as my bud here just got his back and I drive his 1/2 hour so I know first hand. Now Ams has to send theirs out to br to decrypt then receive it back and put their spin on a tune. I know they will have a good one also. Don't know if you knew that. Oh yea I have ss lines also but haven't installed yet
02-19-2015, 09:07 PM | #7 | |
Perennial PFC
336
Rep 1,274
