05-24-2019, 10:57 PM | #1 |
Rep 248
20a211 fault code
Anyone know what this code is?
05-28-2019, 12:40 PM | #2 |
Rep 948
06-06-2019, 03:53 PM | #3 |
M Enthusiast
36
Rep 172
1) Check cooling system for leaks
2) If necessary, fill and bleed the cooling system. 3) If the fault reappears despite the cooling system having been bled and not leaking, renew the coolant pump. |
06-07-2019, 03:25 PM | #4 |
Rep 248
I was a small stone that caused a hole in the aux cooling system. Replaced, re-filled, and now good to go.
10-17-2021, 04:28 AM | #5 |
Rep 99
Drives: BMW F10 M5
Hey all,
I have a BMW F10 M5, with: - Aggressive Project Gamma Cold Air Intakes (they are the best they are routed to behind your kidneys) - Full catless straight piped, with resonators deleted and muffler deleted (sounds insane) - Full exterior mods to take away from the grandpa spec - I have a JB4 tune Anyway, I started getting some codes when I read my codes and I got the code 20A211, and it said coolant pump 2 low, or something to that affect and I know I do not have leaks or any rock chips and I know there is nothing wrong with the pump because only under extreme load would it go limp mode and throw this code along with some misfires (well, I am changing the plugs and coils in a week and this is the first time from factory which I have 62K miles and that is about in the range), but that one code 20A211 through me off, well turns out the intercooler expansion tank was low by like 4", so I got some coolant and replaced it and it has ran great, but I wanted to ask anyone's opinion on why it did this and never told me to add more coolant? maybe because it needs to be under load? and it was only running a bit dry with all the mods and the HP gains. Any opinions here? - |
10-29-2021, 09:36 AM | #6 |
Fueled by Recycled Dinosaurs!
632
Rep 1,172
Drives: F06 M6
Did you coat or wrap the downpipes? They put off a lot of heat. Keep an eye on the coolant level and consider flushing the coolant if you are unsure if it meets specs. Run the car in sport mode for a few miles but don't run it hard. This will allow the car to cool faster before being parked.
If you lost fluid and it isn't coming out the expansion tank or a hose then, in my mind, there is only one other pace for it to go, into the oil. If you haven't done an oil change yourself in a while then I'd make it a priority to do one soon to see if water made it into the oil/pan.
