04-10-2015, 10:43 AM | #1 |
Rep 612
Widest Rear Wheel/Tire Possible
Has anyone tried running a 12 inch wide rear wheel with 335 tire? I just saw a post that someone is running that. Would be curious on fit and offsets.
I just ordered 10 inch wide fronts with 275/35 and 11 inch wide rears with 305/30. Thanks, Tony |
04-10-2015, 11:26 AM | #2 |
Rep 1,917
Yes, it's possible with the right offset. I saw a Morr wheel set with a 345 on the rear. Not sure about the wheel width (12?)
I would run a 285 on 10 inch wheel.
Matt
04-10-2015, 02:17 PM | #3 |
Rep 612
I'm going 275/35 and 305/30 to keep the rolling diameter as close to stock as possible. Many go with stock front tires with 305's in the rear but I wanted to be consistent and go up equally for both.
I would be curious what 20x10 (285/35) front and 20x12 (335/30) rear would look like. The rolling diameter for each is almost identical so front/rear would be equal but it would be much taller than stock. |
04-10-2015, 03:58 PM | #4 | |
Rep 301
Who is this person who has done the 345mm on morr wheels? |
04-10-2015, 06:50 PM | #7 |
Rep 65
I am running 10.5 on the front and 12 on the rear with KW V3. This is done pure for the stance look, if you are using stock suspension I don't think you can run it 12s since the shocks diameter is bigger than KW.
04-10-2015, 08:02 PM | #8 |
Rep 612
Agree with that point. I think I will like my 10 inch front and 11 inch rear. Even though they are wider since they are HRE I should still save weight or at least the gain will be minimal
04-10-2015, 08:03 PM | #9 |
Rep 612
What size tires are you running in the front and rear?
04-10-2015, 09:37 PM | #10 |
Rep 6,067
Check out this online tool
http://www.rimsntires.com/specspro.jsp
04-11-2015, 07:00 AM | #11 |
Curve Thrasher
623
Rep 3,773
Yea Matt, ted says he runs his stock rear tire width on the front. I tell you guys this much, it grips like a bat out of hell when I rode in his car.
04-11-2015, 02:12 PM | #13 |
Rep 1,917
A guy named Ned at MPower Houston shop.
Matt
04-13-2015, 02:20 AM | #15 |
Rep 65
I am running 265 front and 295 rear, again this is purely for stance don't flame me for taking this route. I love meaty tires and "proper" fitment. Since, I am dropping 10k on wheels I want something different than going with the "recommended" offset. If there are more stanced M5, I wouldn't mind disclosing my offset to the group.
FYI, I test fitted the rear wheel on the front. 295 front and 335 is probably the maximum from my quick measurement. |
