      06-06-2017, 07:23 PM   #1
550Reasons
550Reasons's Avatar
Drives: F10 550i
Coding help for Turn off nav/radio with door open
Guys, not sure if on the M5s its different. But in my F10 11 550i I had it coded where I would press to turn off the car just once and then open the door and all electronics would turn off.
I tried to code it the same in my 14 M5, but doesnt seem to work ? I have to press twice for all electronics to be off. Maybe Im coding it wrong, but I still have to press it twice and even opening the door doesnt cut electronics off. Kinda annoying to do it twice. I just want to do it once and be able to lock it.
CAS - 3000 TC, 10 - TC_LOGIC_KLR_OFF_DOOR - set to aktiv
If you set this to active, the radio/nav unit will turn off after opening the door.
Any help is appreciated.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      06-07-2017, 12:12 AM   #2
TMR
TMR's Avatar
Drives: M3
I use BimmerCode and I noticed it in the app. I'll try it tomorrow on my 2016.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/
SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/
SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/
      06-07-2017, 01:56 PM   #3
550Reasons
550Reasons's Avatar
Drives: F10 550i
same, but its active and I still gotta press it twice.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      06-07-2017, 02:59 PM   #4
momos750
momos750's Avatar
143
Drives: 2015 M5, 2011 750Li
You can code it to press button once and then when you pull the door handle open it turns off electronics.
I will look up the code later when I have access to my laptop.
      06-07-2017, 03:31 PM   #5
550Reasons
550Reasons's Avatar
Drives: F10 550i
Thank you
2011 550i
2013 M5
2014 M5 CP
2016 550i
      06-10-2017, 09:26 PM   #6
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
I usually press once and when I lock the doors everything turns off.
      06-21-2017, 10:16 PM   #7
550Reasons
550Reasons's Avatar
Drives: F10 550i
ok so Im new to the M5 / DCT, I came to realize that what I was talking about works if I shut the car off while its in Drive, I was basically putting it in neutral then shutting it off, which would need to be done twice.
2011 550i
2013 M5
2014 M5 CP
2016 550i
