      08-09-2019, 03:23 AM   #1
700_weapon
Drives: Stage 2 F10 M5, M2 Comp
Oil consumption...
So noticed my M5 uses around 1 litre per 1600 miles! (ish) is this normal or excessive?
I'm using this oil right now:
I have a service coming up in the next few weeks, should i stick with the same oil or go for something else?
What works well with a tuned M5?
      08-09-2019, 05:39 AM   #2
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Normal consumption for an M engine.
That said, there are reasons for increased consumption that can be fixed or mitigated. PCV system parts if bad can send more oil into the intakes to get burned. External oil leaks from the engine will make it seem like you're "using" more oil. The oil brand and weight can affect consumption as well. When I bought my F10 it was using about the same amount of oil as you. I have no idea what oil was in the car. I changed the oil to Mobil 1 0w-40 and have continued to use that oil for the next 3 oil changes. After changing it a second time, my consumption had decreased to roughly 1 quart every 4,000 miles! It's been steady since then. Basically I have to add 1 quart between my 5k mile oil change interval.
You are going to get a lot of responses on what everyone's favorite oil is. There are plenty of good brands out there. I'm just related my experiences.
Good luck!
      08-09-2019, 06:42 AM   #3
AddyDaddy
AddyDaddy's Avatar
My 2013 M5 drank about a quart every 750 miles. Techs at 2 different dealers said anything above 600 miles per quart was with in spec? I used to carry a quart in my trunk so when the light went on I could add the needed quart. Some people have no issue, some do.
2018 750M ,
2013 M5 , Individual Silver, Bolt ons-Straight piped
2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete
2024 i5 M60 Cape York Green
      08-09-2019, 08:08 AM   #4
700_weapon
Good luck!
Thanks, will try changing the oil first see how i get on. I'm looking at Mobil 1 0w-40 but it's not showing as an approved oil for the M5 on opie oils?
Just want to make sure i order the right oil:
https://www.opieoils.co.uk/p-68959-m...ngine-oil.aspx
      08-09-2019, 08:10 AM   #5
700_weapon
Mine is a 2013 too!
Dealer saying a quart every 600 miles is crazy imo, i thought 1600 miles was bad!
      08-09-2019, 10:41 AM   #6
aayaz
M Enthusiast
aayaz's Avatar
Drives: F10 Monte Carlo M5
My 2013 also requires a quart every ~1-1.2k miles. I basically do about 3 top offs between each oil change. I'll usually buy a Mobil 1 5w-30 5 quart jug off of amazon for top offs, comes out to be way cheaper than buying a single one each time. I tried to investigate into it when i first got the car but most people, including the dealership said it's normal so don't worry about it too much. If you were losing oil literally right after a full oil service (like 50-100 miles later) then i'd say there is a significant leak somewhere.
      08-12-2019, 04:04 AM   #7
700_weapon
Any help with which to go for....?
      08-12-2019, 08:49 AM   #8
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Never seen that version of Mobil One 0w-40. Might be a US versus UK thing. One I use says something like "formulated for European vehicles" or something similar. Never heard of Millers. Motul and Liqumoly are both good brands. Just make sure the general specification is correct. LL01 or in the UK it might be LL04. Some people like to look more deeply and see what some of the other specifications are and how they rate with turbo engine use.
      08-13-2019, 09:03 PM   #9
M5_Brandoe
M5_Brandoe's Avatar
Drives: Black sapphire M5
I'm around 800 miles per liter.. not sure if tune and more hp plays a part in this
Instagram MRBrandoe
      09-27-2019, 12:09 PM   #10
silentm
Drives: M
Typical consumption for M engine is a liter per 1000 miles. Anything more is winning.
The consumption is based on how hard you drive the car. I miss the dip stick days.
      09-28-2019, 06:07 AM   #11
Dwaynos
Dwaynos's Avatar
I have seen the add oil warning a few times. I've done 3000 miles since last oil change and not had a warning yet.
      10-06-2019, 04:15 AM   #12
Craze
Ive had 4 bmws with 4.4l twin turbo motors
They all have used 1l of oil between 3000-6000km
