05-15-2019, 12:20 PM | #1 |
689
Rep 6,854
▀▄▀▄ Vivid Racing | Capristo Exhaust Valved Exhaust, Mid Pipes, and CES-3 w/Carbon
Vivid Racing Presents: Capristo Exhaust Valved Exhaust, Mid Pipes, and CES-3 w/Carbon Fiber Tips F10 BMW M5 11-16 Contact Me Directly for Exclusive Pricing! Jacob@vividracing.com | +1.480.966.3040 x254 | www.vividracing.com[/b] Product Information: SPECIAL PRICING FOR A LIMITED TIME BMW M5 F10 Valved Exhaust, Mid Pipes, and CES-3 with Carbon Fiber Tips The iconic CAPRISTO Valved Exhaust System offers the best of both worlds through its capability to produce an aggressive exhaust note under acceleration and a more subdued sound for city driving. This feature is possible using vacuum-actuated valve flaps that open and close depending on driving conditions and input from the driver. At lower engine speeds and during cruise operation the valves are closed and produce a deeper exhaust note. At wide-open throttle, the valves open releasing the full symphony of the engine. The exhaust valves are backpressure-controlled and user programmable via the included CES-3 Control Module. The programmable control unit provides 3 modes operated via a remote key fob: - Cruise Exhaust: valves open at higher RPMs - Sport Exhaust: valves open at lower RPMs and hard acceleration - Open Exhaust: valves remain open Both the Cruise and Sport mode can be individually programmed for specific backpressure allowances to determine when the exhaust valves open. This allows precise control of the exhaust based on the driver's personal tastes and tolerance. Capristo Exhaust systems are engineered and manufactured utilizing advanced 3D Laser-Scanning, CAD Design, Digital prototyping, and CNC-bending/milling at our factory in Germany. Each system is made of high-grade T309 (1.4828) Stainless Steel and hand polished to a mirror finish. After extensive research, this specific alloy was chosen for its sonic resonance properties, low weight, and durability which are close to the properties of Inconel (used in F1). Features: - Valved Exhaust, Mid Pipes, and CES-3 with Carbon Fiber Tips - user-programmable via the included CES-3 Control Module - Made from mirror-polished T309 (1.4828) stainless steel - The exhaust system is designed to be installed directly into existing OEM mounting points
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
