01-23-2022, 06:48 AM | #1 |
Rep 3
Power loss on idle sometimes
Hi, i’ve been experiencing power loss on idle sometime after a short drive its like the fuel suddenly stops running and then runs back again (it happens for seconds), i have tried as well injector cleaner several times.
Need your help boys thanks |
01-23-2022, 08:29 AM | #2 |
Rep 19,556
Any codes come up?
When were the air filters changed, have to change them more often where you are and clean the MAF's with CRC cleaner spray. apart from suggesting new spark plugs if they've been in there a long the LPFP may need to be looked at. I'm afraid it's trial and error with these, your best bet is to get BMW to put their tester on it to pin point. |
01-23-2022, 08:35 AM | #3 |
Rep 3
Thats for the reply, i have replaced 8 R8 spark plugs recently, air filters changed 2 months ago, no error codes apart from drivetrain (turbo coolant pump) i changed that as well dono why isit still popping up, i am located in qatar
