      02-18-2015, 05:06 PM   #1
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
New exhaust tips
Bought from Bimmian. VERY good quality. $215/228 shipped.
Tip on left is stock. Tip on right is the new one from Bimmian
      02-18-2015, 05:07 PM   #2
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Pic 2
      02-18-2015, 05:08 PM   #3
rocky
rocky's Avatar
41
Drives: 2015 M5
Hey Phil..... are those tips OEM original size? Do they fit on non CP.?
      02-18-2015, 05:13 PM   #4
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Original stock tip is the one on the right. The new one is on the left. From the pics, it's hard to tell just how much larger they appear.
Yes, they fit both standard and CP exhaust. OEM tips slip right off. These will clamp on via 3 bolts that you compress down onto the factory output pipe from the muffler. Super easy install. Once you see it, you'll see how easy it is.
      02-18-2015, 05:31 PM   #5
rocky
rocky's Avatar
41
Drives: 2015 M5
you are right, hard to tell which one is the larger diameter. I know the OEM is 76mm in diameter.... i was wondering if you know the actual size of the the "new one"? I personally think going from the original size to 90mm is a sweet spot.
      02-18-2015, 05:32 PM   #6
rocky
rocky's Avatar
41
Drives: 2015 M5
...it looks like the one on the right is larger than the left....
      02-18-2015, 07:36 PM   #7
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Correct. It's 3.5" in OD. 88.9mm.
I think you're right... 90mm is a really good size. Though, if I could have it my way, I'd make them a TAD bigger...like 95mm.
      02-21-2015, 09:29 PM   #8
rocky
rocky's Avatar
41
Drives: 2015 M5
95mm would be sweet but i dont think anyone makes that size.. do they?
      02-21-2015, 09:41 PM   #9
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Buddy I recall at some point you got the CF one from ebay... what happened to them? not good quality?
      02-21-2015, 09:52 PM   #10
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
No, they were great quality. SAME exact ones Cyba sells. except I paid $150 less. Lol.
I got these because I'm changing overall look of the car a bit since I got new wheels with polished lips. So I want to change the exhaust tips first.
Then evaluate changing the M5 badge and side gills.
      02-21-2015, 10:15 PM   #11
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Not that I know of. At least not ones you can put on the stock mufflers.
