03-06-2022, 12:18 AM | #1 |
Rep 74
Dsc tyre pressure monitoring and brake errors
Hi guys
I am getting all these errors randomly pop up on my car. Usually when i am not driving aggressively they dont come on. When i drive aggressively they come on some times not always. I have attached a picture of all the fault codes that the car is throwing. The aerial and the trunk warnings are not an issue as they were there before. All others have started popping up now. Where should i start looking first? Thanks
2013 M5, Bootmod 3 stage 2 91 octane, Evolve Catless downpipes
2013 Activehybrid 3, Pure stage 2 turbo with High flow inlet and Dv upgrade, Wagner Evo 2 comp intercooler, ER charge pipes, BMS JB4, BMS intake, BMS Meth kit with a single cm7 nozzle, Fuel it Port injection in 550cc injectors platinum kit with Ethanol analyzer, Fuel it stage 2 LPFP, ER oil cooler kit, Mach v Valvetronic exhaust, Bootmod 3 and running E20 |
03-15-2022, 01:51 AM | #2 |
Rep 74
Any ideas??
I checked all the speed sensors via launch pro diagnostics system and they are all showing the correct speed. Also calibrated the steering wheel center. Still i get the same issue. The issue does not pop up until i start driving the car hard and even then sometimes it does not pop up. What do i look for when it say actual steering angle front axle error? Should i get the car aligned again? Please give me something to work with...
03-15-2022, 06:45 AM | #4 | |
Rep 74
Could it be that they have misaligned something? Thanks
03-15-2022, 07:11 AM | #5 | |
Rep 19,770
I have a '13 also and the alignment has never been checked or adjusted..maybe it's a worn ball joint on a strut making that noise if it sounds metal to metal. |
03-16-2022, 12:15 AM | #6 |
Rep 74
Thanks alot. Dropping the car at the shop today to get it checked. Will update if it is the strut ball joint or something else.
Question is that could it be causing the errors? Or for that alignment has to be checked? |
03-16-2022, 04:44 AM | #7 |
Rep 19,770
The noise started and the axle warning came up,have them check the ball joints and re check alignment and this may all be coming up with when you removed and re-fitted some of that wiring loom. GL.
03-17-2022, 03:22 PM | #8 |
Rep 74
Actually the whole engine had come out and went back in again and the whole front suspension was lowered. When it was put back together the abs and all other errors came up permanently and would not go asay if i would turn the car off and then on again. The steering was also not straight. The shop then jad the car aligned and the permanent errors went away but now i get the errors if i drive hard and that too after a little while but once they start coming they keep coming back again and again. If i turn the car off and on again they go away but come back if i drive hard again...
04-09-2022, 04:33 AM | #9 |
Rep 74
Hi Guys
Was just checking stuff to ascertain the reason for the errors and read different sensors state using ISTA and during testing few readings show status ok and then not available. They keep doing it again and again. I have attached 2 videos below. Is this normal? Thanks |
04-11-2022, 07:18 AM | #10 | |
Rep 74
Error still there what to do? Checked the speed sensors and all show the correct speed also. Do i need to change any module? Thanks |
04-11-2022, 11:51 AM | #11 |
Rep 19,770
I would suggest driving the car normally for a while and keeping the revs down then go from there where you feel, you may need a BMW computer plug in to specifically pin point why those codes come up when you do WOT.
04-13-2022, 12:09 AM | #12 | |
Rep 74
Not related but i tried something last night and went for another drive. I flashed the bootmod3 stage 2 map again which was already on the car but this time in the config i changed the cat cel deactivation from on to oem. Someone suggested that it sometimes interferes with the car and causes these errors. Went for a run and drove the car in every way and no error popped up. I am not sure if it is the permanent fix or last night was just lucky. Will take it for a drive tonite also but is that a known issue? Thanks alot Last edited by vigilante; 04-13-2022 at 12:14 AM.. |
04-13-2022, 05:53 AM | #13 | |
Rep 19,770
04-13-2022, 02:34 PM | #14 |
Rep 74
Ok so went for another drive and error is back. I also got an adaptive front lights error today.
Could i have a faulty steering angle sensor causing all these issues? |
04-15-2022, 12:53 AM | #15 |
Rep 74
Or could it be the short circuit error that is being shown related to the aerial in the rear parcel shelf? When ever i or any other passenger opens and closes any door a remote not present error shows up and it goes away in 5 to 10 seconds. I have noticed sometimes on the gauge cluster an exclamation mark shows on the side randomly while driving and then goes away. Once i checked the notification and it said something about comfort access.
What to look for |
04-15-2022, 04:27 AM | #16 |
Rep 19,770
I know that coding a lot of things to owners preferences can cause problems if the car is sold on without returning it to original factory settings and the comfort entry can add to the problem when warnings flash up after a big mechanical lay up.
I went out of my way to avoid a car with comfort entry and non essential extras like st wheel lane buzzer,NV,steering wheel heat,b&0 etc when looking for one with so much electronics in this car. I know it doesn't help you but if continuing warnings then I suggest a BMW visit to return the car to factory settings with the tune switched off. |
04-19-2022, 03:21 AM | #17 |
Rep 74
ok so checked and cleaned all the wheel speed sensors and connectors and went for a drive still the same. All the abs,dsc and flat tyre monitoring errors came.
Now shop is checking the dsc unit wiring and they found some wires had tears on them. They are taping these up and will go out for another test drive. I have attached herewith the pictures. Could these wires be the issue. Also in the pictures does it seem like the dsc unit is repaired? Could that be the issue? Thanks
04-20-2022, 07:43 PM | #19 |
Rep 74
Ok problem solved. The icm module was not mounted securely causing the errors. Its mounted and all is good.
Thanks. Unusual problem but i hope it helps someone.. |
