12-27-2018, 05:22 PM | #1 |
Rep 248
Fault code help - Fault Code: 191E08
Fault Code: 191E08
Fault Explanation: :Tank ventilation system 2: Malfunction Any idea what this code is used carly to pull the error. |
01-09-2019, 08:47 PM | #3 |
Rep 248
Replaced fuelcap wasn't that i'll let my tech know about the pressure vent. But i believe he checked all of that. He did a smoke leak test it came back negative. Were looking at replacing the valves that are on the IC's tomorrow to see if those.
Is it possible when the dealer did a reset of the ECU on my car they fucked up some coding? I've read others had Can coding issues? Anyone ever hear of this.
01-10-2019, 09:47 AM | #4 |
Rep 248
Bump - anyone any thoughts before i just start replacing parts. Is this something that a reflash from the dealer could cause with missing can bus codes?
01-19-2019, 05:46 PM | #5 |
Rep 222
