05-05-2013, 09:48 PM | #1 |
Rep 37
can anyone recommend a radar detector?
just got speeding ticket on my way back from shenandoah in Virginia....sigh
83 on 55, but cop didnt give me reckless and say i could just call and pay the fine over phone i want to get a radar detector and wondering which one is good to use in virginia? i saw another member is posting about Escort 9500 xi, is that good? thanks! |
05-05-2013, 10:08 PM | #2 |
Rep 978
The Escort or the BEL STI-R are probably the two most used on the board in my opinion. I personally have the BEL STI-R, stealth mounted and the Laser Blinder setup for laser detectors. There are few threads here on the board with pix and recommendations.
2021 M340i
05-05-2013, 10:23 PM | #5 |
Rep 1,341
Drives: 2013 M5 SSII
1. Valentine1 - old school but proven
2. Escort 9500xi - new school and simple to use (what I have) 3. BEL STi - basically same as 9500 with more options/controls (stealth will probably correct me) Any of these are awesome. Get the hardwire kit and route it to your glove box fuses. Mine paid for itself on the way home from best buy If they are illegal in your state, you may want to opt for a true hardwire install (Escort 9500ci, Bel Stir Plus) , so it's not exposed visually. Much more $ though.
05-05-2013, 10:50 PM | #6 |
Rep 994
+1 for Escort. I used to have the Escort 9500 and it worked very well. I ended up switching to the Escort SmartRadar because it integrates with my iPhone. Can't go wrong either way.
05-05-2013, 11:03 PM | #7 | |
Knight Commander
554
Rep 5,948
2022 Mercedes-Benz EQS 580
05-05-2013, 11:55 PM | #8 |
Knight Commander
554
Rep 5,948
Heres my take:
The best: Bel STIR+. This detector has maximum range and sensitivity, which means it does a tremendous job of picking up instant-on or quick trigger radar where other detectors fail (V1 can do this to some extent but not 100%of the time). Note this detector is likened to the 9500ci but the 9500ci has similar range but doesn't have the sensitivity needed to pick up quick trigger (it is actually about par with the V1 or slightly lower in regard to quick trigger radar). The other advantages of the Stir+ are it's concealed, it is undetectable by spectre, it can filter out known falses using GPS which means its alerts are meaningful, and it can warn you of traffic cameras. The only drawback is it is expensive ($1000 + $400 to install). Worth every penny though. It's saved my hundreds of times. Others worth considering: 1) Escort Redline. shares the long range of the Bel Stir+ and is the longest range windshield unit you can buy. It doesn't have GPS filtering so you will get falses. Also doesnt have advanced settings to pick up quick trigger. It can still do quick trigger about on par with the V1 which is about 30-50% alert rate. Drawbacks: false alerts a lot on K band 2) Valentine Research V1. Pretty good range, pretty good pickup on quick trigger (30-50%) but it can still occasionally be beaten. Has arrows which is nice. Drawbacks: false alerts a lot, lacks the range of the top Bel and Escort models, K band can be weak if you turn on K band false suppression (DSP). 3) Escort 9500ci. Has excellent range on KA band (better than V1) but on K band can be slow to alert (it picks it up early but for some reason doesn't alert unless signal is strong). Uses GPS to filter false alerts which improves the relevance of alerts. Warns of cameras. Drawback: not so great with quick trigger, and not great with K band. Nonetheless is one of the top picks thanks to its balanced and cutting edge feature set and impressive KA band range. Also if the police in your area use laser, you should not depend on a radar detector as it will lure you into a false sense of safety.
05-06-2013, 05:30 AM | #9 |
Rep 317
v1 is great with the arrows but you need to turn POP off because of interference with the m5. because of this I would suggest one of the others.
yesterday was my first long drive (300+ miles) and it seems like range is significantly shorter with POP off. no idea what POP does, but I felt a lot less confident.
'22 Macan GTS
'21 911 C2S '20 Cayenne '16 X5 50i M-sport (3rd row!) |
05-06-2013, 10:46 AM | #10 |
Rep 190
Drives: 2018 Alpina B6 GC & 2019 M5C
I live in NOVA and I have the Bel STIR+. It is stealth and expensive, but totally worth it. I have everything in the grill of the car, controls hidden inside the car and the display in my rear view mirror. I got mine done at a place in MD, but there is a place in Tysons that does it as well but I can't vouch for them. I looked at the 9500ci as well and I was told that the only difference b/w it and Bel STIR+ is the color of the display (blue vs. red). There's also a place in Boston that I thought about going to that can put the radar and laser notifications in the HUD, but I didn't feel like driving up there and they aren't open on weekends.
Also, I keep out of state tags on my car and that allows me to remove the front license plate. Although cops can hit any flat surface on the front or back of your car, most of them like hitting the license plate for an accurate read b/c it's usually the flattest part of the car. So, if you can remove the front license plate that may buy you some time in some situations. |
05-06-2013, 10:53 AM | #11 | |
Rep 1,622
05-06-2013, 11:00 AM | #12 |
FROZEN SILVER
112
Rep 466
V1
CURRENT RIDES - 16 991 GTS 7MT/ 12 FROZEN SILVER E92 M3 / 03 GPW S2K AP1
PREVIOUS M CARS - 02 E39 M5 / 06 E60 M5 / F10 M5 6MT 14 991 C2S |
05-06-2013, 11:00 AM | #13 | |
Internet Crash Test Dummy
331
Rep 1,055
Works great http://f10.m5post.com/forums/showthread.php?t=776392
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
05-06-2013, 11:07 AM | #14 |
Rep 190
JMH provided the right info and the guy at SIM was really cool, but I wasn't trying to drive up there in the winter.
05-06-2013, 11:13 AM | #15 |
Rep 571
I opted for the bel stir+. I have very few false alerts, mostly due to the filtering of band segments, and also I mark known falses on my regular routes so they no longer alert.
05-06-2013, 12:09 PM | #16 |
Rep 3,206
There are many good choices for radar detection (and don't forget laser) but I think that much of the choice is narrowed by price. In a place like Virginia where detectors are illegal, you may want to go with a fully concealed system, but be prepared to pay over $3k for the product plus a good install. If you want concealed radar + laser detection, I think the most obvious choices are the Escort 9500ci or the Bel StiR+ combined with Laser Interceptor.
CURRENT: '24 M4C Conv
RETIRED : '23 M8C Conv | '20 X4 M40i | '18 M4 6MT | '13 M5 6MT | '08 550i 6MT | '04 545i 6MT | '98 540i 6MT | '94 530i 5MT | '84 528e 5MT Other retirees from Chevrolet, Buick, Subaru, Honda, Acura, Merkur(!), Volvo, Saab, Audi and Porsche Last edited by hinckley; 05-06-2013 at 12:15 PM.. |
05-06-2013, 12:42 PM | #17 |
Rep 11
1. Redline (best off-axis detection + range + filtering)
2. V1 (good range + arrows + great laser scatter detection) 3. 9500XI (Good for most people who aren't enthusiasts, doesn't have range of the first two) If you want to dish out the money as everyone said Bel StiR+
F10 M5 Alpine White / Sakhir Orange
H&R Springs, Sakhir Orange Calipers, 4F/2R Laser Interceptor, Valentine 1 + Redline, BlackVue DR400G |
05-06-2013, 12:54 PM | #18 |
Curve Thrasher
620
Rep 3,773
[QUOTE=ONO5OH;13942001]1. 9500XI (Good for most people who aren't enthusiasts, doesn't have range of the first two)
Question for you:::: How do you come to the conclusion for the people who purchased the 9500xi arent enthusiasts? Thats a lame statement and certainly not true. Just saying bro.
Country run |
05-06-2013, 12:54 PM | #19 | |
Knight Commander
554
Rep 5,948
The closest thing is to place the display in the line of sight. The Bel STIR+ display is miniscule so I have mine placed in line of sight. It's almost as good as HUD.
05-06-2013, 01:09 PM | #20 | |
Rocky
411
Rep 3,085
[QUOTE=boots;13942068]
05-06-2013, 01:23 PM | #21 |
Rep 1,917
Had the V1 for a number of years. Recent software updates gave it too my false alerts, so I opted for a 9500xi with the Live protection. I've been pleased... Accurate reads, with the ability to lock out false alerts, and the Live app is nice because it will give you audible alerts through the bluetooth audio -- this is especially good when I have the stereo turned up loud and it's hard to hear the radar! :-)
Matt
05-06-2013, 01:29 PM | #22 |
Curve Thrasher
620
Rep 3,773
Im glad you posted that McVaughan as I'm pleased with my 9500xi so far when I made a trip to Austin yesterday.
Country run |
