      03-12-2018, 06:06 AM   #1
M5BMW
Drives: M5 F10
Exclamation Best Downpipes
Hi Guys,
There's quite a few options out there for catless downpipes. Is there any out there that are a real cut above the rest? Can titanium be used for downpipes? Which company makes the best?
M5BMW
      03-12-2018, 09:48 AM   #2
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
Ti is expensive (over 1500). I would go with Fabworx or VRSF for the price/quality.
      03-12-2018, 10:20 AM   #3
M5BMW
Drives: M5 F10
Who makes titanium downpipes for the M5?
      03-12-2018, 12:08 PM   #4
TheHouseWon
644
Drives: 2013 M5
Evolution Raceworks I believe
      03-12-2018, 01:36 PM   #5
M5BMW
Drives: M5 F10
They're steel.
      03-12-2018, 01:46 PM   #6
TheHouseWon
644
Drives: 2013 M5
Ok, I remember it was with ER or Fabworx that could do Ti. They do it custom though not off the shelf.
      03-12-2018, 10:47 PM   #7
Dracon
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
I'd just gut your stock downpipes. Or buy an OEM set off eBay for like $200 and knock the cats out (so you still have your original pipes to put back on).
Sounds awesome and a lot cheaper, better fitment.
      03-13-2018, 04:15 AM   #8
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
try AMS, they are great
      03-13-2018, 04:53 AM   #9
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
When it comes down to it they are all pretty much the same. Some have better welds than others. I would advise wrapping them or ceramic coating, cheap to do before install and helps prevent heat soak through DP's.
      03-13-2018, 03:48 PM   #10
Craze
I got ess downpipes
They seem quite good
      03-13-2018, 07:44 PM   #11
Rocketsoda
'13 M5
Drives: 2013 BMW M5
[QUOTE=Dracon;22905612]I'd just gut your stock downpipes. Or buy an OEM set off eBay for like $200 and knock the cats out (so you still have your original pipes to put back on).
Would gutting the stock cats cause issues if the CEL light stays on? Someone mentioned the ECU might cut power? I'm down to gut the stock downpipes but want to make sure leaving the light on won't be a problem
      03-13-2018, 07:54 PM   #12
TrevorM3
Drives: 6.3 AMG
[QUOTE=Rocketsoda;22910070]
buddy of mine did this. gutted them, and bungs stayed in place so no issues iirc
      03-14-2018, 07:14 AM   #13
TopEnd
Drives: 2014 BMW M6 Gran Coupe
[QUOTE=TrevorM3;22910109]
friend of mine gutted the OEM and it threw a CEL. However, his sounds better than mines i must admit. im running coated enzo DPs
      03-14-2018, 07:27 AM   #14
gdavis
gdavis's Avatar
35
^^^^This plus ceramic coating
'14 M5 CP
      03-19-2018, 11:35 PM   #15
Mookster
Mookster's Avatar
184
Drives: 2019 ZR1 & 2020 Supra GR LE
Any major benefit of aftermarket DPs versus say OEM Catless DPs?
      03-20-2018, 12:18 PM   #16
josec70
josec70's Avatar
None that I'm aware of, in fact, OEM fitment will be perfect and that's a plus versus aftermarket.
Have them wrapped or ceramic coated.
      03-20-2018, 02:42 PM   #17
TheHouseWon
644
Drives: 2013 M5
Aftermarket weighs less, that's really the only benefit.
      03-20-2018, 06:16 PM   #18
WickedBMW
WickedBMW's Avatar
Drives: 2021 BMW M3 MT
A bit more hp
      03-21-2018, 10:51 AM   #19
josec70
josec70's Avatar
Originally Posted by WickedBMW View Post
A bit more hp
I don't believe aftermarket Dps will offer a HP advantage over gutted OEM.
      03-21-2018, 03:37 PM   #20
WickedBMW
WickedBMW's Avatar
Maybe 5-10hp
      03-22-2018, 11:40 AM   #21
josec70
josec70's Avatar
Maybe 5-10hp
You believe aftermarket dps will offer 5-10 more hp over gutted OEM dps? How do you figure this?
      03-22-2018, 11:55 AM   #22
TheHouseWon
644
Drives: 2013 M5
$800+ ($3,300 for catted Capristo!) for an additional 5-10 HP? Vs. OEM fitment and double-walled for heat control.
