06-11-2015, 09:03 AM | #1 |
Rep 2,320
m5 and winter
Hello guys
i was wondering to ask, do you often drive into a mountains with your beloved m5, how does it act on snow, do you use chains or not? Thanks
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
06-11-2015, 09:10 AM | #2 |
Rep 262
I have a set of winter wheels and tires. Even with these I hesitate to drive long distances in the snow.
Not sure if you can get chains for these cars, or if you'll risk damaging the wheels, however I did come across something called a tire sock or something like that. |
06-11-2015, 09:34 AM | #3 |
Rep 4,721
for winter driving on mountain range, do bring a shovel, extra clothing and survival kit for the 'just in case'. After all, even with good winter tires, the M is only good to drive up to around 25cm of snow and anything beyond this with sloping elevation may mean trouble of being stuck or stranded.
06-11-2015, 11:27 AM | #4 |
Rep 1,231
Proper winter tyres are a must. Last winter on summer tyres I almost got stuck in 1" of slush and a 2% gradient. This happened on a major freeway off-ramp leading onto a mega roundabout. I went to pull onto the roundabout and the car moved so slowly thanks to wheel spin I thought I was going to get nailed by a truck. Chains probably don't fit on summer wheels due to clearance isssues.....check with BMW if the all square winter wheel set up will accept snow chains. Snow chains are only good for roads covered in snow. And they provide a very uncomfortable ride so don't expect to drive far with chains mounted
06-11-2015, 12:25 PM | #5 |
Rep 292
Drives: 17 M2 - 14 M5
Over the winter I tried to pull my car out of the garage to move it and center it. There was less then an inch of snow and well the wheels just spun and spun. Traction control activates and well three hours later with salt and sand we got the car back in the garage.
Don't be that guy with the fancy sports car who drives in sub freezing temperatures with summer tires and crashes into a telephone pole. |
06-11-2015, 12:39 PM | #6 |
Rep 764
Of course you cannot drive in snow with summer tires. Seriously, anyone who tries should have their head examined.
But with a proper set of winter tires and rims, a reasonable amount of snow and slush can be safely navigated. Twisty mountain roads are certainly more trying. Personally I wouldn't do it, but if you know the roads and conditions, it can be done. Drive carefully. You cannot use chains on an M5. |
06-11-2015, 12:41 PM | #7 | |
Rep 292
06-11-2015, 12:49 PM | #8 | |
Rep 764
Seriously, how did you do on your winter set then? |
06-11-2015, 12:53 PM | #9 | ||
Rep 292
06-11-2015, 12:59 PM | #10 |
Rep 764
I can imagine with more than 4" of snow the M5 becomes a plow. I drove my 650 thru 3 winters on a good set of winter wheel/tires, but I am vacillating between a set for my M5 or just getting a winter vehicle.
06-11-2015, 01:07 PM | #11 | |
Rep 292
06-11-2015, 04:11 PM | #13 | |
Rep 1,231
I drove a car all winter on winter tyres. It didn't snow once. In March I refitted my summer tyres. It snowed in April |
06-11-2015, 04:23 PM | #14 |
Rep 1,844
Snow tires will be OK on flat plowed roads.
Hills (even small ones) are problematic. I had trouble getting up my driveway with snow tires on the M5 this past winter and am considering studded tires for next year. |
06-11-2015, 04:49 PM | #15 |
Rep 128
I have a set of winter wheels and it is ok, but I have not driven with heavy snow.
You can also put some snow chains for 245 tyres sold at bmw dealers. I try however not to drive with snow to avoid corrosion of salt. |
06-11-2015, 05:15 PM | #16 | |
Rep 764
But seriously, and I mean this to all readers, do not drive on snow or slush with performance summer tires. They have no sipes and cannot grip snow or slush. The also become rock hard at temps below 40 F (give or take). It is very dangerous. You're my forum family. We need to look out for one another. Besides, I cringe at the thought of a wrecked M5. |
06-30-2015, 09:35 AM | #17 |
Rep 2,320
Thanks guys for all answers....
06-30-2015, 02:43 PM | #19 |
Rep 73
Winter should generally not be a problem.
But some points to take into consideration: . winter tires are a must . to get better traction, the owner's manual recommends MDM to allow for some wheel slip: the standard traction control setting cuts in too early to be able to gain momentum . depth of snow: no the M5 is not a SUV : ) so a certain depth of snow is ok but not deep snow . instead of chains, the Autosock(.com) can be an alternative . for winter I have the 409M wheels with Dunlops: works very well . in Switzerland, have driven in snow without problems . And remember the first promotion video clip for the M5: it was on snow... maybe they wanted to get a message through . and once you get the car gently sliding it is very controllable Hope this helps |
07-01-2015, 11:51 AM | #20 |
Rep 2,320
okay i hear u guys one more thing do u guys think that e60 m5 v10 sound was better than f10 m5 v8?
07-01-2015, 11:58 AM | #21 |
Rep 301
07-01-2015, 01:20 PM | #22 | |
Rep 2,320
and v10 like more f1
