      10-20-2023, 09:20 AM   #1
Danishp97
Drives: BMW F06 M6 GRAN COUPE
Ibs error intelligent battery sensor
Hi guys, I had a new battery installed from the dealership 2 months back, battery state of charge on bimmerlink shows 99 %. However whenever I scan the car i get lots of weird codes. When I clear it all go away but the IBS code stays. The other day I started the car and I got the increased battery discharge when stationary message on the idrive. Scanned with bimmerlink the following codes show up -
00 Junction box electronics
3 errors
8020DB: Battery sensor, WakeUp line (WUP): Short circuit to ground or line break 8020E8: Terminal 30F reset / shutdown
C90DBE: K-LIN_7 emblem: switch end stop
10 Central gateway module
2 errors
801C10: Request to reset terminal 30F alarm clock 801C11: Request to switch off terminal 30F alarm clock
12 Motor electronics
1 error
CD8F01: LIN, communication (intelligent battery sensor): missing
3F Active sound design
1 error
8053A5: Invalid encoding data for Equalizing
40 Car access system
1 error
9307BA: One or more DAYS blocked due to game protection
56 Roof function centre
2 errors
DE8C5E: LIN Sine, communication failure 801A52: SINE: Coding data write error
Upon clearing all codes all codes go away but the CD8F01 code stays. Anyone in here??
      10-20-2023, 09:41 AM   #2
Would like to help Danishp97 but electrics are not my forte'.
      10-20-2023, 09:44 AM   #3
Danishp97
I always appreciate whenever I have posted you have always replied!
M5Rick60060.50
      11-07-2023, 10:28 PM   #4
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
On the negative battery terminal is the IBS. There is an elector a connector on it, make sure it’s plugged in and not damaged. The tech installing the battery may have unplugged or damaged it.
2014 M5 6MT
