      10-08-2017, 02:39 PM   #1
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
Warranty claim history
Hey guys, I'm trying to gauge if I want to buy a used M6 GC out of warranty or not.
I figured best way is to ask what fixes owners of M5s have actually claimed under factory warranty to date.
So what has actually broken on your specific car thus far that was claimed under warranty?
      10-08-2017, 02:45 PM   #2
ykjones
Master Gunnery Sergeant
ykjones's Avatar
Drives: 2013 F10 M5 Signapore Gray
Man I've been very fortunate and have only needed 02 sensors replaced under warranty but there is no way I would even think of buying a M5 without an extended warranty. I like having the peace of mind.
VF Engineering Hex Stage 1, RPI GTM Black edition, KW HAS, Dinan sway bars, Matt Schnell spacers, IND black chrome, M Performance rear spoiler, M Performance rear diffuser, Michelin Pilot Sport 4S's, ESS stainless steel brake lines, EBC Red Stuff ceramic pads, BMC air filters, charcoal filter delete, sprint booster, V1w/Blendmount, BIM coding all options, Pedal Haus pedals, Formula One Pinnacle Tint
      10-08-2017, 03:28 PM   #3
Flying Ace
Flying Ace's Avatar
4985
So that's what I wanted to avoid discussing. The entire "unknown issues". Certainly M cars had their demons in every generation (vanos, rod bearings), but aside from the bogeyman issue that pops up in year 7+, I really just want to know immediate issues that has popped up within the first 4 years or so.
My estimated ownership will be in years 4 to 8.
Thanks, 02 sensors noted. Not a major issue IMO.
      10-08-2017, 04:17 PM   #4
TrevorM3
Drives: 6.3 AMG
u want to own an m5/m6 out of warranty? let me simplify it for you.
dont.
you may think its reliabe, which is most part is true, but the moment you need a repair, it;s going to cost you. big time
      10-08-2017, 05:44 PM   #5
basic.sportscar
Drives: e90 M3 manual
O2 sensors
Turbo oil line
Fuel pump
Alternator
I have extended warranty and have used it numerous times.
      10-08-2017, 07:06 PM   #6
Flying Ace
Flying Ace's Avatar
4985
dont.
Again, thanks, but please share actual experiences. My E90 M3 has been the most reliable car I've ever owned. Cost to fix is certainly high, no debate here...But I specifically wanted to know what have you fixed on your M5/6
      10-08-2017, 07:07 PM   #7
Flying Ace
Flying Ace's Avatar
4985
Originally Posted by Sgnitsah View Post
O2 sensors
Turbo oil line
Fuel pump
Alternator
Seems like oil leaks from the oil lines appears to be common?
      10-08-2017, 08:01 PM   #8
Mkai0
Drives: F10 M5 Black
I had a full clutch pack that was replaced under warranty, due to the previous owner launching multiple times. The previous owner is also a regular here on the forums. My ac also isn't blowing cold air now-I'll find out in a few days if it's a freon or a condensor issue. The parts and labor for these items in the past 1 1/2 years easily could've easily cost me $3500 if I didn't have a warranty. The car is semi-expensive to repair.
      10-08-2017, 09:20 PM   #9
josec70
josec70's Avatar
13’ M5- Power Steering Failure, Fuel Pump, Coolant Lines and several other items that I don’t remember.
15’ M5 - No issues to date.
No two cars are alike and, as such, I would not own one of these cars w/o a warranty.
Good Luck!
      10-09-2017, 11:35 AM   #10
mfarad
Front brakes and rotors. Turbo coolant lines leaked. Clutches then a complete Transmission. Turbo oil lines. I'm currently having power steering issues. 51XXX miles. 13
      10-09-2017, 11:54 AM   #11
Flying Ace
Flying Ace's Avatar
4985
Are there any major parts components that BMW has extended 10 year warranties on?
      10-09-2017, 09:18 PM   #12
DL7
My fuel tank leak diagnostic module warranty was extended to 10yrs/120K miles.
Also, had O2 sensors replaced.
      10-10-2017, 09:06 PM   #13
Maverick997
Maverick997's Avatar
49
Drives: 2014 M5 Black Saphire Metalic
Battery, rear ac blower motor, steering column ( due to vibration issues) other than that no issues...2014 currently at 55k miles.
Other toys
'07-997 Turbo....EVOMS 580..AWE exhaust...champion intercoolers..champion springs.
'91-964 Turbo K27 Hf turbo...Techart Exhaust...etc, etc
      10-14-2017, 10:32 PM   #14
1MEANM6
1MEANM6's Avatar
Drives: M6 GranCoupe
In my ownership of a 2014 M6 GC i only ever claimed for high pressure fuel pump and injectors (injector changed due to failure of high pressure fuel pump)
