      11-20-2017, 10:01 PM   #1
ONE_slow_m5
Drives: 2020 f90 m5
Meth Setup on FBO + pure stage 2's
Was wondering what everyone thats making about 800whp is running for meth.
I bought an aquamist meth kit. How many nozzles are you guys running and where are you spraying? In the charge pipe or after the charge coolers? Also 50:50 or 100% meth?
2020 BMW m5 f90 Project gamma intake downpipes charge coolers . Awe Exhaust Pure_performance_TX stage 3 build motor e40 ABP tune snow performance meth kit
2018 x6m Built motor stage 3 tune PG downpipes
      11-21-2017, 05:49 AM   #2
financenick
Drives: BMW M5 F10 - 2016
charge pipes is much easier than after the charge coolers (although not best for power) i don't bring the meth on till later when using 50/50, but when i run pure meth it responds better when sprayed earlier
      11-21-2017, 02:41 PM   #3
schnell1982
Drives: FAST
If you are planning on making 800WHP
Sure hope you are replacing your clutches and rod bearing shells
      11-21-2017, 03:15 PM   #4
ONE_slow_m5
Drives: 2020 f90 m5
all done already
      11-21-2017, 06:27 PM   #5
schnell1982
Drives: FAST
Nozzle guide
N20/N26: Single CM7
N54/N55 with factory turbo(s): Single CM10 or dual CM5
N54/N55 with larger hybrid turbo(s): Single CM12 or dual CM7
B48 with factory or larger turbo: Dual CM5
B58 with factory or larger turbo: Dual CM7
S55 with factory turbo(s): Dual CM5
S55 with larger hybrid turbo(s): Dual CM7
S63TU with factory or larger turbos: Dual CM10
      11-21-2017, 06:29 PM   #6
schnell1982
Drives: FAST
Above is the chart I got from Burger Motorsport website.
I have used this chart on 4 separate water/methanol injection systems I have completed.
2 - S55 Engines
2 - S63TU Engines
I run 50/50 "Boost juice" from Snow Performance and for the injection site I use the BMS charge pipes with methanol bungs pre-drilled.
      11-22-2017, 10:20 AM   #7
steeve13m
I run 100% VP racing meth with dual CM14's ! I get a 60 pressure reading on the meth gauge value..
      12-13-2017, 03:02 PM   #8
Dandadda
Dandadda's Avatar
Drives: 2014 M5 COMP PACKAGE
What are you guys using for your meth control? any of you using JB4? if so do you ever encounter issues with over boosting when running on map 8?
2014 COMP PK M5
MSR INTAKES
AMS ALPHA DOWNPIPES W/CATS
JB4 w/BCM
      12-20-2017, 02:44 PM   #9
steeve13m
JB4+BCM controls the meth safety using map8 only
See thread;
http://www.n54tech.com/forums/showthread.php?t=41272
      12-20-2017, 06:09 PM   #10
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
See thread;
Safety related to wastegate adaptation is available in multiple maps. Meth safety is available in Map 8 (not Map 6).
You can turn WG adaptation off and try to customize FF/PWM... but not for the faint hearted!
      12-20-2017, 07:13 PM   #11
schnell1982
Drives: FAST
Use the JB4
Terry at Burger Motorsport will assist you with logging and dialing in your settings.
      12-20-2017, 09:41 PM   #12
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
I'm using the snow performance stage 3 kit. I have spray starting at 6psi and full spray at 15psi. I'm not tuned for it and I always use 94oct. I'm basically using it for cooling and octane purposes. I did run 10.8@137mph with a 1.9 60ft. Before that I did 10.8@132.
