      05-21-2014, 12:51 PM   #1
greentrbo95gst
greentrbo95gst's Avatar
1231
Drives: 21 M5 Comp
Chirping sound
The sound is driving me crazy and it started about a week ago.
I know this was discussed here, but I did a search and nothing came up.
Any help would be greatly appreciated. THanks
      05-21-2014, 01:03 PM   #2
Mbdurham17
Mbdurham17's Avatar
159
Drives: 2016 M5 CP
Hit a bird and stuck behind the grill? couldn't resist sorry
I had a 928 that was doing this apparently they were notorious for it and it was a drive shaft bearing
      05-21-2014, 01:04 PM   #3
Mbdurham17
Mbdurham17's Avatar
159
Drives: 2016 M5 CP
Pic
      05-21-2014, 01:06 PM   #4
greentrbo95gst
1231
Drives: 21 M5 Comp
LOL, thanks for cheering me up. I should probably add that it happens under deceleration at very low rpms.
      05-22-2014, 12:22 PM   #5
greentrbo95gst
1231
Drives: 21 M5 Comp
nobody?
      05-22-2014, 12:46 PM   #6
Spinny02
Spinny02's Avatar
Brearing?
      05-22-2014, 12:53 PM   #7
greentrbo95gst
1231
Drives: 21 M5 Comp
Originally Posted by Spinny02 View Post
Brearing?
It's not a rotational part.
      05-23-2014, 12:04 AM   #8
Jdubya
Drives: 2014 550i
You sure it's not just the blow off valve for the turbo? Should happen after the turbo has spooled up pressure and you let off the throttle, it blows off the excess pressure. Sounds like a chirp.
      05-23-2014, 07:19 AM   #9
boots
Curve Thrasher
boots's Avatar
623
Can't think of anything
      06-01-2014, 03:41 AM   #10
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
I had the same issue and it went away on its own.
Only happened between 1000-1300 rpm.
There was a guy on here who made it go away with new gaskets between the DP and exhaust.
BTW, both of us have Akra. But if you dont have Akra ...it might be related to re-using the OE gaskets with any aftermarket exhaust.
http://f10.m5post.com/forums/showthread.php?t=969452
      06-01-2014, 03:06 PM   #11
turbo8765
Drives: very fast
Waste gate?
      06-01-2014, 10:20 PM   #12
greentrbo95gst
1231
Drives: 21 M5 Comp
Good call on the gaskets. I have AMS dp's and Meisterschaft exhaust.
      06-03-2014, 09:11 AM   #13
Timberwolf
Timberwolf's Avatar
196
Drives: People crazy
AMS typically supplies new gaskets in their recent DPs. When did you install yours? Mine had em.
Or you could be experiencing "screech factor" that's when your wife is shrieking for you to slow the eff down!!!
991 Turbo
993 GT2 Outlaw
      06-08-2014, 02:17 AM   #14
M5essex
M5essex's Avatar
England
642
Drives: RR sport SVR, Vent S, 650s spi
I think Ive heard this lots recently too. Is it the closing of the exhaust valves? Or are you valveless/ straight through? Some times I think its suspension when in comfort that is chirping or squeaking over bumps but then I hear it on even roads when decelerating too...
      06-09-2014, 01:52 PM   #15
greentrbo95gst
1231
Drives: 21 M5 Comp
I control the exhaust valves with the wireless remote.
I believe it's the gaskets in between dp's and catback.
      06-11-2014, 12:26 PM   #16
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
Crazy... my chirping just came back last night
I never replaced the gaskets cause my chirping went away.
      06-11-2014, 12:48 PM   #17
greentrbo95gst
1231
Drives: 21 M5 Comp
Lol, let me know what fixes it. My car has been parked for two weeks.
      06-11-2014, 01:12 PM   #18
M5Rlz
Drives: R8, f10m59(Rip), m4, GTR
I've heard those... I thought I was crazy lol
      06-13-2014, 05:50 PM   #19
Evooooo
Drives: 335 XI Sedan M Sport
Ball joint, check suspension. It's happening on my V right now, worst noise ever.
      06-14-2014, 12:50 PM   #20
M5Rlz
I don't think so, I had the car in when they stuck two new rears on and all my vibrations are gone, and its still doing it... They said they looked all the suspension over, so I doubt if it was a visible ball joint it would do that... Also like others have said it only happens on comfort setting not sport/sport plus
