06-22-2015, 06:55 PM | #1 |
Hide! My wife's coming!
812
Rep 2,816
F10 M5 Vibration
I recently picked up a used low mileage F10 M5. Immediately while braking around 40 mph or from higher speeds I noticed vibration. Took it to dealer and it was diagnosed to be warped rotors. When I picked up, it felt as the issue was corrected with the new rotors and brakes.
Lately, I have started feeling vibration again while braking but not as excessive. Only 1k miles on the brakes and rotors, is it possible that they are warped again???? I don't drive it hard. Also, anyone else notice vibration/shudder in the steering wheel in low speed turns. Mostly felt when pulling in/out of lot. Might be an issue or not but maybe it's related to a suspension issue. |
06-23-2015, 07:32 AM | #3 |
812
Rep 2,816
06-23-2015, 08:33 AM | #4 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
One of the wheels might be slightly buckled but within spec.
07-20-2015, 09:22 PM | #5 |
Rep 84
Are you running stock springs? Do you know if previous owner had the 'clunk' issue fixed? Early 13's had a problem with shorter springs in the rear that caused a thump on bumps. I had this fixed per SIB and immediately noticed all my road vibration was also gone. Others have reported vibration is resolved with new springs. Not sure if your issue is related, but I would recommend getting this done nevertheless if you haven't already.
2013 M5 BSM/SS - BMS Stage 1, Turner Race Exhaust, 12mm spacers, KW HAS, Dinan sway bars, IND cosmetic package, LED kit, V12 coded
07-20-2015, 09:59 PM | #6 |
Rep 1,805
Once you get the RF wheel repaired Im sure the issues will be sorted.
07-23-2015, 01:43 PM | #7 | |
812
Rep 2,816
Thanks |
07-23-2015, 01:44 PM | #8 |
812
Rep 2,816
07-23-2015, 06:44 PM | #9 |
Rep 84
07-23-2015, 11:08 PM | #10 |
Rep 346
08-21-2015, 08:51 AM | #12 |
812
Rep 2,816
Bent wheel must have been the issue because once I repaired my wheels and had them powder coated gloss black, the vibrating went away. I still have something and I have it scheduled for a road force balance next week.
