06-24-2014, 08:41 AM | #1 |
Rep 166
Delete resonators on CP exhaust?
I'm considering a low cost mod to the stock CP exhaust setup to get a little more growl. I already have the Exhaust Meister. Do you guys recommend removing the resonators as the next step? My understanding is that an exhaust shop can remove the resonators and put them back on rather easily if there's a ton of drone or if it's too loud. Any insight would be appreciated.
Raj
Current Stable
?19 M5 CP ?19 X6M |
06-25-2014, 07:16 AM | #3 |
Rep 1,840
No drone and sounds great. This is what I am running.
06-25-2014, 07:50 AM | #4 |
Rep 166
Nice. Do you remember what the labor charge was? I would think it's a straight forward job for an experienced muffler shop.
Raj
Current Stable
?19 M5 CP ?19 X6M |
06-25-2014, 08:31 AM | #5 |
Rep 1,840
I received the Eisenmann center pipes from stealth pilot and had them installed. Cost was only a few hundred. I would assume cutting the res out and replacing the small section with like ss pipe should be about the same price. You just need to find a shop who can tig weld on stainless.
06-25-2014, 08:52 AM | #6 |
All I do is Win... Eat Race Sleep
152
Rep 2,184
Drives: 2018 Range 2011 M3 2019 600lt
You should check out Undercover Performance in South Jersey they did a full custom exhaust for me.They can deff do this for you.... You can check out the quality here http://f10.m5post.com/forums/showthread.php?t=962461
Rs7 : 10.4 133.50 with a 1.7 60ft Toyo R888 F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires |
