04-28-2016, 12:36 PM | #1 |
Rep 131
Drives: 2023 i4M50
Spacers with 305/30/20 tires
Traction issues so was thinking of the 305/30/20 set up, but would these tires and 10mm front and 12mm spacers be to much? Will it rub? Please help!
05-17-2016, 01:51 PM | #2 |
Rep 281
me 2 i wanna switch out my tire to the 305 also but i dont want it to hit my fender or rub on anything and btw i have the f10 m5 rim size is 20x10 any pics or videos will help and it have to be mpss bec i just replaced my front 2 tires from hitting a rock so i dont wanna mix up tires
05-19-2016, 10:07 PM | #4 |
Rep 8,083
i think we should start a thread where everyone posts detailed pics of their car.
provide details such as spacers, comp pack or not, which kit etc. think it would be incredibly helpful. |
05-21-2016, 07:29 AM | #5 |
Rep 232
I don't think the 305's will make much of a difference for traction. There is not that much difference. I hear Toyo R888's provides the best traction for getting out of the hole and racing
05-22-2016, 11:21 PM | #7 |
Rep 131
Drives: 2023 i4M50
Any pics with spacers 10mm? All around
05-23-2016, 08:57 AM | #8 |
Rep 563
I don't have any pics with 10mm spacers all around.
I run 12/10 f/r setup with my stock wheels and tires. If I were to run a spacer with 305s it would be 5mm. |
05-24-2016, 12:06 PM | #9 | |
Rep 131
Drives: 2023 i4M50
05-31-2016, 10:14 PM | #10 |
Rep 1,155
305 vs 295 adds 5mm poke. If you were running 12mm spacer on stock rear (as I did at one point), you'd only need a 7mm spacer with the 305.
So from recollection, yes, a 305 + 12mm spacer rear would rub. I ran stock +12mm spacer at all corners and it was near perfect flush. I'm sure I posted pix at some point. BTW - I ran 12mm all around. 12 looks better than 10 front, imho.
2009 Aston Martin DBS - Casino Royale Gray on Black (sold) 2014 M5 ZCP - Azurite Black over SSII Full (gone) 2009 M5 - Carbon Black over Sepang Full (gone - not forgotten) 2001 740i M-Sport - Carbon Black over Black (gone - not forgotten) |
06-01-2016, 07:14 AM | #11 |
Rep 232
I am currently running 12mm on all 4 corners. I know the recommendation is 10mm on the front, but it wouldn't make a noticeable difference.
Before... After... |
07-04-2016, 12:28 AM | #12 | |
Rep 131
Drives: 2023 i4M50
07-04-2016, 12:16 PM | #13 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
Please see this thread for pictures and discussion on 305/30/20.
PZeros are a great tire and I've run 3 sets at least on the rear. I've loaded a new tune that is a hang of a lot of power so I tried R888s. They're great but don't expect to get much more than 3000 miles out of a set and they're terrible in the wet vs the PZeros which do well in the rain. From first hand experience (last night) R888s in the wet are terrifying! http://f10.m5post.com/forums/showthr...1113050&page=4
07-07-2016, 12:22 PM | #14 |
Rep 131
Drives: 2023 i4M50
Putting on my 12mm spacers today. I went with Apex.
07-07-2016, 02:18 PM | #15 | |
Rep 131
Drives: 2023 i4M50
07-07-2016, 11:48 PM | #16 |
Rep 1,805
Your reason for putting spacers on the wheel - I trust spacers don't compromise safety.
07-08-2016, 01:20 PM | #18 |
Rep 131
Drives: 2023 i4M50
07-08-2016, 01:23 PM | #19 | |
Rep 60
07-08-2016, 11:04 PM | #20 | |
Rep 1,805
Always get the Pirellis in 99Y 305s. R888s been fun tire.
07-21-2016, 11:18 AM | #21 |
Rep 881
Well, I just made the switch from 295 to 305 pzeros.
I'm lowered on H&R springs and was originally running 12mm spacers all around. With the 305 and 5mm spacers, it is very slightly tucked in vs. 295 and 12mm spacers. If you are not lowered, you can probably get away with 305 pzeros 99Y and 10mm spacers, but it would be close. edit: this is on stock 343m wheels |
07-22-2016, 08:45 AM | #22 |
Rep 1,805
5mm is what I hear can work on the rear and ensure no rubbing. Ive personally never bothered running spacers with 305 tires. Currently running 315 rear tire and spacers would be a problem.
Fast.F10513.50 |
