      07-29-2016, 02:08 PM   #1
alex91
Drives: 2013 M5
AC recharge
Guys,
I've already searched the web, but still can't find where the low pressure AC recharge valve is on 2013 m5. Nothing in the manual or under the hood. The one valve that I thought it would be, under the left cover next to the front headlamp, but the gage to measure the pressure doesn't fit it. Can someone show me on a picture?
Thanks
      07-29-2016, 03:29 PM   #2
momos750
momos750's Avatar
143
Drives: 2015 M5, 2011 750Li
Usually on the same side near the dryer or accumulator. Maybe under the air intake box? Good question!
The port under the passenger side headlight cover is def the high side port. You can charge through the high side also but with liquid only, no gas. You should not attempt that unless you know what you are doing.
      07-29-2016, 04:14 PM   #3
LI-M5
Drives: 2016 M5
Originally Posted by momos750 View Post
U You should not attempt that unless you know what you are doing.
^^^^ wat he said , im no mech but im no idiot either have attempted 2 x's on diff cars and f--k'd em both up ! do it urself kits from pep boy's w gauge ended up at dealer or auto mechanics 2xs lol ..
$80-100 get you done professionally evac and charge only way to do properly imo..
Neil
      07-29-2016, 04:43 PM   #4
momos750
momos750's Avatar
143
The problem with DIY kits is that you are charging based upon pressure (low side).
All AC units whether it be a home unit or automobile need to be charged by weight (pounds/ounces) of refrigerant, based on manufactures specs.
You can DIY charge and be within the right pressures but it may be under charged or overcharged.
      07-29-2016, 09:34 PM   #5
ur20v
I believe they are under the left hand airbox lower.
      08-01-2016, 06:45 PM   #6
lanab
Drives: M5 F10 MY12
Nah...you should not touch that when refilling, only the other one in the front is enough according to BMW manual in Rheingold.
I changed my condenser two weeks ago, it was leaking everywhere due to stones hitting it and it started to crack.....
Problem is that the opening grilles are so big compared to previous generations, it really needs some mesh protection behind it or it will happen again, Porsche 991/992 owners have the same problems and they are even worse, this is a real pain problem to have as it's not only F10 M5 that's affected but also other BMW series.
DIY charge kits are a waste and makes things worse in the long run as you also need to apply oil to the AC compressor which the DIY kit doesn't supply, the only thing you do is making the AC compressor running dry on oil until it stops, just let a real AC guy make the refill or change the condenser as that is probably 99% your problem.
      08-02-2016, 08:11 AM   #7
Bowser330
Drives: i3 REX
Filling to manufacturer specs is very important, I had an Indy shop overfill the ac system in my f30 335i and the ac would blow hot air when on the coldest setting! I took it back to the shop, they used another neighboring shops ac recharge system and got it filled correctly to mfg spec. After that it started blowing ice cold. I think It's something about having enough room in the system for expansion of the fluid. It's worth going to an Indy shop to use a professional system just make sure they are refilling to mfg specs for your car.
      08-02-2016, 08:20 AM   #8
alex91
Drives: 2013 M5
Thanks for your replies.
All I wanted to do is to check if my pressure was low. Between then and now, I've brought my car to the dealer and asked them to take a look. The driver side vents were blowing slightly warmer air vs the passenger side; that's in addition to the overall less than ice cold AC, even when on the max setting. Turns out something is not right and the shop is checking for leaks and anything else that could contribute to the issue. They confirmed that the pressure was too low. Let's see what they find out. I should hear back today.
Alex
      08-02-2016, 01:54 PM   #9
alex91
Drives: 2013 M5
It turned out to be a leak. The dealer is replacing one of the lines/hoses.
      08-06-2016, 06:51 PM   #10
lanab
Drives: M5 F10 MY12
Yes filling to manufacturer spec is important, the M5 should have 850mg.
      08-07-2016, 09:06 AM   #11
alex91
Drives: 2013 M5
A quick update for those who might be experiencing the same issue. The SA told me that this kind of problem is not common. Don't know if that's bs or not, but here is the write up from my paperwork.
"Replaced AC pipe"
"Found 0.62 lbs refrigerant in the system, charged system, add dye in the system, checked for leak, verified leak from suction pipe, recover AC system, replaced suction pipe, vacuum and recharge AC system with spwc 1.60 lbs refrigerant, add dye, rechecked for leak, no leak found".
The AC is running strong now.
      08-30-2016, 11:36 AM   #12
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Alex
Do you still have the driver side blowing slightly warmer?
      08-30-2016, 12:48 PM   #13
mister2d
"Replaced AC pipe"
Was this a warranty repair?
      09-04-2016, 11:07 AM   #14
alex91
Drives: 2013 M5
The AC runs strong from all vents and I can't feel any difference between the vents.
The job was covered under warranty.
      09-06-2016, 02:31 PM   #15
mister2d
Thanks. I just had mine serviced due to no cold air at all. The dealer found no leaks so they drained it, re-oiled and recharged my system with dye. Charged me the rate for AC service. If it does leak this time it will leave residue. Mine wasn't covered under warranty. Bummer.
      07-25-2017, 05:15 PM   #16
jgugalde
jgugalde's Avatar
Drives: 2013 F10 M5
Can anyone Tell me where to locate the low side charge port on a 2013 f10 M5?
      07-25-2017, 07:45 PM   #17
HussainM5
Kuwait
37
Drives: M5 f10
recharge A/C location
under passenger side air box
      07-25-2017, 09:07 PM   #18
TrevorM3
Drives: 6.3 AMG
car looks good with red calipers
      08-01-2017, 10:49 PM   #19
jgugalde
jgugalde's Avatar
Drives: 2013 F10 M5
Thank you so much for the information! I checked both low and high pressure sides and they were both a bit low compared to the R134a pressure chart. I added a can an 1/2 of R134a with PAG oil to get the Low and High pressure side to spec and now the AC is cooling much better.
I will check it again one of these days to see if it is a leak. I don't suspect is a leak as it was cooling but would take some time for the cold air to get going inside the cabin.
Thanks Again for the help!
2010 E90 N54 335xi/ JB4 G5 ISO/ BMS CP/ VRSF 7" FMIC/ Forge Motorsports DV/ Borla Cat-Back Exhaust
2013 F30 N55 335xi Waiting to be Tuned
2013 F10 M5 BMS ChargePipe Custom Intake
      08-02-2017, 08:29 PM   #20
BMWM5NYC
BMWM5NYC's Avatar
496
Drives: 2013 F10 Monte Carlo Blue M5
I work in the HVAC field. Your system is a sealed system, the only way it was low on refrigerant is if A. Someone let some out, or B. There is a leak. That is the only way you would be low on refrigerant.
Formally known as BMWM3NYC
      08-03-2017, 10:12 AM   #21
DHUBM5
Drives: 2014 BMW M5
"Replaced AC pipe"
I had the same thing happen to me, just they replaced the condenser as well (all under warranty). Like you, they told me this isn't common but I'm starting to think otherwise...
2014 BMW M5 Comp Singapore Grey Metallic
Modifications: Gintani tune (91 and VP110 (724 rwhp)), MSR intakes, Akrapovic EVO exhaust, HRE S101, Evolve Catless Downpipes, Michelin PS4S, Vorsteiner Rear Diffuser, RW Carbon front lip and rear spoiler, M Perf Alcantara Steering Wheel, IND paint matched front and rear reflectors, Rayno nano carbon ceramic tint (40%), Hardwired Escort 9500ix
      08-10-2017, 11:38 PM   #22
jgugalde
jgugalde's Avatar
Drives: 2013 F10 M5
Hi, it did not look like it was a leak because it still cooled down but took some time. After adding R134a to required pressure, the system is holding up. No apparent leak. I don't know if it came that way from factory. So far so good.
BMWM5NYC496.00
