03-02-2016, 04:42 PM | #1 |
Rep 612
Anyone running 11.5" rear wheel
Currently I'm running HRE P40s in 20x9.5 et 25 front and 20x11 et 32 rear. 265/35/20 and 305/30/20 tires.
I'm selling my current M5 to a friend and will be picking up a 2015-2016 Comp Package M5. Since I'm going with the same car and with HRE's again (probably P101's this time) I was hoping to at least go with a little different size wheels. I really don't want to go with 21's due to many factors including horrible roads here, limited tire options, and less sidewall to hook up. However, I would like to try 20x10 up front and 20x11.5 in the rear. I know the 10" inch wide will work with no problems up front but will 11.5" fit in the rear? I was thinking to go with 20x10 et 28 up front and 20x11.5 et 35 in the rear. Pretty much both would sit out an additional 18 mm. I would run the same 265/35/20 and 305/30/20 tire setup. Feedback? |
03-05-2016, 10:02 AM | #2 |
Rep 29,202
Can't you just check the inside of the rear wheel well? I'd think it's enough room since I have 11" wide rears on my non M5 with room for at least 11.5".
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
03-15-2016, 07:35 AM | #3 |
Rep 22
Yesterday, out of curiosity, I have fitted an F15 X5 wheel 21x11.5 ET38 and 325/30 tire on my M5 and it seems that with a 305 tire it would fit. It's a close one definitely but the wheel was about 1cm from the shock and in line with the fender.
03-15-2016, 09:09 AM | #4 | |
Rep 3,834
03-16-2016, 10:43 AM | #5 |
2146
Rep 1,837
Drives: Many, BMW.
I have a 21x12" - had 305/30/21 fitted on it, no issues. I know 12.5" is doable with some really accurate ET measurements and tire combination.
03-16-2016, 11:13 AM | #6 |
Rep 3,834
Damn... Are you running K&W V3s? Not sure if V3 reduces tire clearance as it does for the F80.
03-16-2016, 11:57 AM | #7 |
2146
Rep 1,837
Drives: Many, BMW.
03-16-2016, 12:45 PM | #8 | |
Rep 3,834
Good news. There is a cheaper alternative to V3s. CKS coilovers have good reviews.
03-16-2016, 02:40 PM | #9 | |
2146
Rep 1,837
Drives: Many, BMW.
Only reason why I ended up going w/ H&R's is cuz I never had issues with them on all my previous cars, and by the time the suspension felt bouncy, it was time to turn it in... this time around, i still got a 9 or so months left and I drive the shit out of my car. :/ |
03-16-2016, 04:32 PM | #10 |
Rep 612
What was the offset? Maybe I will just let HRE handle the offsets to ensure it works out. I think 20x11.5 et 35 would work well.
04-01-2016, 12:00 PM | #11 |
Rep 1,658
Yes an 11.5" wide rear would fit but why would you? The only tire that can fit (without body modifications) is a 305. A 305 fits perfect on an 11". The wider you go the more you will be stretching the tire.
www.WheelsBoutique.com || David@WheelsBoutique.com || 786 249 0127 ext. 2109 YouTube Channel: https://www.youtube.com/user/WheelsBoutique |
04-01-2016, 08:49 PM | #12 | |
Rep 3,834
03-18-2017, 06:04 AM | #13 |
Rep 579
Anyone have more info on 11.5 or 12.0 rears for the M5 ?
Thinking of running 10x20 front and up to 12x20 rear with 305's I agree with going wider with the rim for turn in and feel |
03-18-2017, 10:38 PM | #15 | |
Licensed Drug Dealer
742
Rep 2,271
11's would suffice and they would be less heavy also. +1 on the stretch comment also. |
03-19-2017, 12:42 AM | #16 | |
Rep 6,071
Why do you want your gorgeous M5 looks like Honda Civic? There is a reason manufacture spec the 305 tire for 10.5"-11.5" not 12".
03-19-2017, 11:25 AM | #18 |
Rep 579
PS the width of the 305 PSS is 12.3 - 12.5 inches if I recall from the specs depending on which one, but a 12" rim will measure something like 12.8-12.9 rim edge to rim edge.
03-19-2017, 11:28 AM | #19 |
Rep 579
Have a look at the recent reviews of the 911 GTS, same size 305/30 on a 12" rim
Specs here http://cc.porsche.com/icc_euro/ccCal...fmodelstart%2f Not very Civic like to me ! |
03-19-2017, 01:32 PM | #20 |
Rep 917
I'm going with 325/25 next on my 21x11 Seemed to work well and looks good
http://f10.m5post.com/forums/showthread.php?t=1000505 Edit not my car this is M6beast (George) of MSR. He's also running 325 on his M6 but on 12's I believe |
