      11-12-2015, 08:52 AM   #1
Drm5
Puerto Rico
30
Drives: F10 M5 sakhir orange
dyno says 781 whp!!!!!
well took my car on monday for tunning after the methanol placement... my car has msr intake, charge pipe, ipe exhaust , ams downpipe and JB4...
gas was 93oct
map 2 on 4th gear was 680 whp
map 8 meth 75 additive 4th gear 715
map 8 meth 75 add... 5th gear 765 whp
map 8 merh 100 add 5th gear 781...
ok I know is 5th gear but we saw a few thing on las pull either the transmission went on limp mode at around 6,000 rpm were it reached 781 or the speed limiter activated, but we are pretty sure it was the transmission... the engine just keep going and turbos didn't max out...
I will add the dyno..
      11-12-2015, 03:24 PM   #2
AstonMartian777
Drives: 2014 M6 F06
meth add 100 shouldn't even work.
      11-12-2015, 05:12 PM   #3
Drm5
Puerto Rico
30
well it did..!!!
      11-12-2015, 06:51 PM   #4
David 12
David 12's Avatar
127
Drives: 2019 BMW X5 50i BSM, M Sport
Looks like you tied another PR poster, djtallrick!
Good job!
Dave
      11-12-2015, 07:36 PM   #5
momos750
momos750's Avatar
143
Drives: 2015 M5, 2011 750Li
Exactly what I was thinking. Dyno graphs look surprisingly similar. :
781hp Dyno Night! http://f10.m5post.com/forums/showthread.php?t=1193604
      11-12-2015, 07:44 PM   #6
MCarsFan
MCarsFan's Avatar
Drives: 2014 BMW M5 F10 CP
2014 BMW F10 M5  [10.00]
+1
Anyway what's the point if you aren't running a stack? Hitting the limiter must be balls man..
      11-12-2015, 08:18 PM   #7
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Originally Posted by MCarsFan View Post
+1
Is everyone 781whp now?
You can't run 100 on Map 8. It's impossible for stock turbos to flow enough air to make 750+ real horsepower.
I want to see VBOX times. With this power you need to match or beat my 6.2s
      11-12-2015, 09:11 PM   #8
Lerxst M4
Lerxst M4's Avatar
Drives: F82 M4
That's it, I'm driving to PR tomorrow and getting on this dyno...I need 781!
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone)
2013 F10 M5 (gone)
2008 E90 M3 (gone)
      11-12-2015, 10:09 PM   #9
m6beast
m6beast's Avatar
185
Drives: stock m6
That's because it's the same car
One is the person who did the work and the other is the owner of the car
      11-12-2015, 10:15 PM   #10
momos750
momos750's Avatar
143
One is the person who did the work and the other is the owner of the car how hard is it to understand lmao
It's very hard to understand since none of that was explained in either one of the specific posts.
      11-12-2015, 11:01 PM   #11
m6beast
m6beast's Avatar
185
Drives: stock m6
Understood....
I know because the guy who did the work emailed me the dyno graph with mods listed and the owner of the car is a loyal customer of mine. He's a doc so I don't think he really cares on the details other then his car running strong and being happy with his results.
I can't give any details for I'm not there to know how the car was tuned by the tuner and what adjustments they made when running the JB4.
Hopefully the tuner can chime in to give some light. If he doesn't will just have to wait and see as others push the envelope. I would have data to post but I need clutches before my car can get on the Dyno to prove its power potential
From my experience I feel the Dyno is showing about 50whp above normal figures. Just by map 2 showing 680whp that's usually around 630whp at my biddies Dyno. So the 780 would be around 730whp. That is my opinion not a fact. If it's truly 780 whp that's awesome a great results.
Good luck Doc, glad your car is showing some impressive gains. Enjoy it and keep me in the loop
G
      11-13-2015, 12:35 AM   #12
momos750
momos750's Avatar
143
Understood....
G
Thanks for the clarification George. Numbers look great! Would be great to see more detailed info on the tune.
      11-13-2015, 07:40 AM   #13
Msizzle
Drives: 2013 M6 Coupe
Guys look I hope this engine can make all this power like we see on these crazy dyno's but up to now we have 1 10 second slip out of all these cars. At that power lever with some DR our cars should go about 10.50 if not faster and trap about 133 or more. Up to now all we have is crazy dyno's and 1 10 second car.
      11-13-2015, 07:45 AM   #14
Msizzle
1 other question, what boost level does it take to do this, I would think upwards of 28psi. Can our turbo's do that? IF so what about the injectors, they aren't maxed out?
      11-13-2015, 07:53 AM   #15
M5Rlz
Drives: R8, f10m59(Rip), m4, GTR
I'm ready to give it a run. I only put down 950whp and 875wtrq at 29psi on a mustang dyno that reads about 17% lower than Dynojets
      11-13-2015, 08:12 AM   #16
m6beast
m6beast's Avatar
185
Drives: stock m6
My M6 did 10.7 @ 129mph with just jb4 meth and bolt ons
On my M5 with custom tune and BCM pushing boost at 28lbs boost the car is a lot faster then my M6 was then, the issue now is traction and I don't think anyone will get close to a low 10 second pass. It will be hard to find a happy medium to get a perfect launch to show its true potential. The best place for our cars with these power figures are highway races or Vbox but even a Vbox doesn't prove who is stringer then the other unless the runs are done on the same road in order to be comparable. Some even find a road with a negative slope to get the best numbers they can. Either way it's just the beginning so with time you'll start to see more and more M's in the 750-800whp figures.
As for turbo upgrades I feel the best option is to wait for larger internals then just going the hybrid solutions. Once again that's my opinion some may disagree.
As for my M5 My issue is clutches, at least for dynoing the car. Once I upgrade the clutches will see what the Dyno will show. But I can say the car is a lot faster with the BCM pushing boost.
My customer in NJ has upgraded his clutches so we see what tuned and BCM will show here in the states. My guess 750-780 whp and as long as he's using 20" wheels. 21's have proven to show 20-30whp less in the Dyno
Anyway great job Doc keep us in the loop
      11-13-2015, 10:52 AM   #17
allmotor_2000
1087
I have 1/2 time-slips and VBOX 1/4 traps 132-136. Traction is a b***h on these. I have some M/T to try at the next Bakersfield event Dec 12th so lets see what happens there (it should be cool finally).
60-130 is 6.2s (with slope) and 6.3s (< 1% slope) and 100-200 is 5.3s - both VBOX verified
      11-13-2015, 10:53 AM   #18
allmotor_2000
1087
Originally Posted by m6beast View Post
Understood....
G
That makes more sense. 781whp on Map 8 is next to impossible especially with stock turbos
      11-13-2015, 02:36 PM   #19
Speed808Ix
Speed808Ix's Avatar
69
Drives: F10 BMW M5
781 sounds awesome but can't believe it!! hahaha
2015 BMW M///5 Comp. Package I Black Sapphire Metalic I Full Black Leather I Gruppe M Intakes I 3D Design Side Skirts I HRE FF01 I RKP Lip I IND Cosmetic Pkg I JB4 BETA I BMS Meth SS I MSR CP I Challenge SS Brake Lines I Challenge Diffuser I Undercover DP's I Dodson Clutch Packs I VRS GTS Tips I M Perf. Carbon Mirrors, Spoiler and Full Interior +++
698 WHP & 653 WTRQ (Corrected)
      11-13-2015, 05:42 PM   #20
Drm5
Puerto Rico
30
sorry guy's.. I will talk with kenneth wich is the guy that tunned the car to chime some info... tomorrow will be doing a 1/2 mile event and I guess will see what we can do... I think mrs intake provide better inflow that any other out there... so I will get back on sunday and let u guys know...!!! and yes the car feels very strong... btw the other post was made by a BMW sales person.. not the tunner
      11-13-2015, 06:17 PM   #21
M5Rlz
Totally agree people start slapping 3076R,35R,37 sized turbos on these cars or something its not if you might hit a breaking point its when.
My recommendation if you're having clutch issues call the master. John Shep is doing DCT BMW trans [m4 record] My shep trans stage 4 has been out of this world.
      11-13-2015, 06:41 PM   #22
allmotor_2000
1087
Look forward to this - please also record VBOX results as some 1/2 mile events tend to be longer or shorter....
At shift-s3ctor MPH's were within 1mph, so they had setup the distance quite accurately,
