03-18-2016, 09:34 AM | #1 |
Rep 241
Dinan Stage 1 ... Worth it?
On otherwise stock M5. Can the car actually hook up on dry, warm pavement?
How hard is the tune on the mechanicals? Owned car vs leased! |
03-18-2016, 07:39 PM | #2 | |
Rep 616
It is a noticeable difference from stage 1 > stage 2 The harness is reversible and can remove without any issues if you sell or return on lease. No long term issues or stress on engine component's. Plus, Dinan has their own backed warranty program. If you have the $$ and want peace of mind that you wont have issues with the dealer, then go with Dinan |
03-18-2016, 09:38 PM | #3 |
Rep 18,717
@Rearview , it is very worth it if you are more into the warranty coverage than anything else.
It has a good quality and superb customer service.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
03-18-2016, 10:33 PM | #4 |
Rep 241
I have read about issues with Stage 2 and to stick with Stage 1 on a stock setup (no downpipes, etc). I presume Stage 2 is more aggressive on boost and associated fuel:air mixes?
03-18-2016, 11:31 PM | #5 | |
Rep 1,519
Dinan is pretty much conservative on any stages they mKe their piggy like jb But their piggy is still low on power due to they dnt want an aggressive tune on their warranty cars. Reliability on them is prolly ok |
03-22-2016, 03:26 PM | #6 |
142
Rep 639
Zero issues with my Stage 2 tune.
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) |
03-23-2016, 08:33 AM | #8 |
Rep 843
does anyone know the difference between stage 1 and stage 2? It isn't not very clear on their website, it looks like they only test stage 2 with their intake and exhaust.
03-23-2016, 09:29 AM | #9 |
Rep 3,129
Correct, we only test with the intake and exhaust on stage 2 as that is what it was designed for. Stage 2 is really based around the intake more then anything; tweaking AFR's to compensate for the increased flow, etc. Can you run stage 2 without the intake? Yes, but we wouldn't recommend doing so just because we have found those that do that method to have a much higher instance of CEL's being triggered and other issues. The M5/M6's are a bit more finicky then the other platforms in this regard. Stage 2 will still garner you a bit more power without the hard parts technically as there is a pound of peak boost increase on its own. You will just not realize the full reported gains is all.
03-23-2016, 08:50 PM | #10 |
Rep 616
Stage 2 is a noticeable improvement of power all around.
Stage 2 is comparable to overall performance of BMS set at 3/3.5 I have tried and tested this with a M6 gran coupe and M5. Both clients cars that switched from BMS stage 1 and went to Dinan stage 2 have all positive feed back on how much better Dinan performs overall compared to BMS stage 1 |
03-30-2016, 09:26 PM | #13 |
Rep 241
To Dinan:
Saw a couple of threads where some M5 CP guys saw no noticeable gain from Stg 1. They alleged that Dinan rep stated that BMW under rates their advertised HP and that it is closer to the 620-630 range vs the advertised 575. Hence, the Dinan gain of 91hp is closer to ~40hp @ the crank. Rep also alleged that Dinan was going to correct their claim (this was in the Fall of 2014) or modify their Stg 1 offering. First, is any of this accurate? Second, has Dinan modified / evolved its Stage 1 tune from late 2014 to present? (new firmware?) On a non-CP, stock F10 M5, what are dyno readings with and without Stg 1. Is there any 'satisfaction guarantee' within 7-10 days post-install? I'd be bummed to spend $3k on a piggyback for 40hp @ the crank (would be tough to detect a 3-4% hp increase net of drivetrain drain) Thanks for any clarification! |
03-30-2016, 11:08 PM | #14 | |
Rep 222
03-31-2016, 11:20 AM | #15 | |
Rep 616
Of course JB4 is going to have more features then any harness on the market and produce more gains. I like BMS product's and install many of them for clients that request them. But there are differences in between all the companies piggy back units. Everyone knows that a JB4 will be faster then Dinan, ESS, Active..pretty much any car with just a piggyback |
03-31-2016, 11:26 AM | #16 | |
Rep 616
Until Dinan chimes in the some specifics on the fine details of the software updates. I do know that there have been a few firmware updates for this platform. If its performance of software updates I do not know that. There is for sure a large noticeable power increase with Stage 1 I have not dyno tested any clients cars to post up any gains but, the power is there and every client that received Dinan has been very happy with it. Contact your local Dinan Authorized dealer and ask if they offer any type of specials for you. Last edited by A Frankfurt; 03-31-2016 at 11:57 AM.. |
03-31-2016, 02:49 PM | #17 | |||
Rep 3,129
Kind of accurate, sort of. When the tune was originally released the stock rating that we measured was not present on the website although it was listed on the performance charts. This led some people to accuse Dinan of falsely reporting gains by "taking credit for gains that we did not produce" by assuming we took credit for all power from the rated horsepower to tuned when in fact the data points as presented below were always displayed. Just not specifically listed / called out. Misleading the gains was never the intent by any means and it was simply not as clear as it could have been was all. The graph below shows data points at various RPM's comparing stock and stage 1 on the M5 CP along with the delta. Quote:
03-31-2016, 08:09 PM | #18 | |
Rep 241
03-31-2016, 08:12 PM | #19 | |
Rep 241
The #'s above look pretty 'badass'! |
04-01-2016, 07:55 AM | #20 |
Rep 3,129
04-01-2016, 01:29 PM | #22 |
Rep 3,129
DINANTRONICS is tied to the original VIN it was installed on for warranty purposes. If the unit was removed from the originally installed vehicle and put on another M5 it would work just fine but it would not be associated with that VIN and thus hold no warranty.
