05-04-2016, 09:43 PM | #1 |
Rep 785
Downpipes install help!!
Has anyone installed their down pipes by themselves?
How hard is it to separate the down pipes from the mid pipe? What exactly do I need to do at that point? I know how to access the down pipes from the engine bay but that's about it. I want to go into this install with as much info as possible. |
05-04-2016, 09:49 PM | #2 | |
142
Rep 639
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) |
05-04-2016, 10:39 PM | #4 | |
Hide! My wife's coming!
812
Rep 2,816
05-04-2016, 10:39 PM | #5 |
Rep 785
05-04-2016, 10:41 PM | #6 |
Rep 785
I have instructions that came with the downpipes, it just stops at the point of removing the downpipes from the midpipe. I have access to a lift. But I want to be 100% sure of what to do before I waste time on the lift (pay per hour)
05-04-2016, 10:57 PM | #7 |
Rep 1,890
Drives: M5 CS / iX 50i
Make sure to get new gaskets between the turbo and downpipe, and between downpipe and exhaust.
Its maybe a 3 hour job if you take your time. It was pretty easy, just aligning the new down pipes were a bit of a pain, twisting and turning to make it fit. From underneath, its just loosening clamps between the downpipe and exhaust, then tightening them back up. Overall, it was back breaking work if I didnt climb up on the engine bay; then again I'm only 5"8
https://www.instagram.com/day_laborer/ (DM me from this account) Email: nextlevelautobrokersdc@gmail.com Part-time with Next Level Auto Brokers, LLC https://www.instagram.com/nextlevelautobrokers/ |
05-04-2016, 11:12 PM | #8 |
1506
Rep 676
Drives: '17 F31 340xi US Spec
Downpipes are a DIY job on the N63/S63. No need to fully remove exhaust and you do not even really need a lift. Just a little advice, align both of the turbo flanges and exhaust clamps Before tightening everything. After everything is aligned, tighten the turbo side first. Also I hope you are planning on replacing the turbo side gaskets.
05-05-2016, 01:14 AM | #9 |
Rep 788
Access underneath to the 4x 13mm bolts/nuts (2 each side) is easier if you remove the alloy sump guard, you can see the bolts but its at an angle. Not sure if you can do it all from above like spider feet (Day Laborer) is possibly doing?
05-05-2016, 01:59 PM | #11 |
Rep 1,250
Drives: 20' X3M CP
And pray when you turn your car on it doesn't rattle. Pretty sure like 90% of the M5's after going catless rattle like crazy.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
05-05-2016, 10:48 PM | #12 |
Rep 2,039
From m5board:
Fitment for the downpipe is very specific. Make sure you follow our installation notes (or print this out and give it to your installer). Installation notes: - Exhaust of the car does NOT need to be removed. Simply loosen the exhaust nuts on the bottom and bring exhaust downward WITHOUT fully removing it. Removing the exhaust will make it harder to lined up the downpipe from the top. - Once, the bottom of the downpipe is inserted into the 2 bolt exhaust flange, LINE UP THE DOWNPIPE TO THE TURBO flange. If the downpipe is inserted too DEEP into the 2 bolt flange, the center radius of the downpipe will hit the engine cyl head and you will have fitment issues. It is extremely important that you follow these notes. - Do NOT tighten brackets until EVERYTHING that holds the downpipe in place is installed. - Make sure the car is FULLY cooled. If you are doing the installation yourself, we recommend letting the car sit for a few hours with the hood open. Installation time: 2-3 hours (cold car) http://raceprecision.com/images/bmw/f10_m5/downpipe/ |
05-05-2016, 11:05 PM | #13 |
1506
Rep 676
Yep, the rattle is really a huge side-effect of downpipes. We are actually working on having a solution for this in our reflash. So far, we got this issue resolved on N63 platform and soon will have it available for S63 as well.
05-05-2016, 11:06 PM | #14 | |
Rep 1,250
Drives: 20' X3M CP
good stuff.
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | Last edited by combatbmw; 05-05-2016 at 11:18 PM.. |
05-06-2016, 09:29 AM | #17 | ||
Rep 2,039
I posted a load of pictures here EDIT: See #12 and #13 |
05-06-2016, 11:22 AM | #18 |
Rep 3,834
Links no workie.
05-06-2016, 11:58 AM | #19 |
Rep 8,083
thanks!
also quick question. lets say someone were to add dp's to the m5, without doing any tuning/coding etc... is there ANY benefit to it at all? obviously you would get the sound. but that's about it, correct? |
05-06-2016, 12:08 PM | #20 |
Rep 2,039
05-06-2016, 05:59 PM | #21 |
Rep 881
Anytime you remove restrictions in gas flow (ie cat removal) you'll always see *some* improvement in power.
05-06-2016, 06:13 PM | #22 | |
Rep 715
A lot more power with a flash tune.
