01-17-2017, 05:40 PM | #1 |
Rep 188
Definative Methanol Injection Power Increase
Hi,
Does anyone have raw data on 'before and after' power figures for their meth upgrades. Dyno'd with and without meth on.. -Interested to know exactly what power can be achieved with just this one mod |
01-18-2017, 03:54 AM | #2 |
Rep 788
With just water/meth or even straight meth you won't gin much if anything out of the stock set up, you need a JB4 or other piggy or a flash tune.
With a tune, for most it just gives some head room on fueling and ignition, they won't run past 23psi and the clutch limits which I think is about <650whp. Its not strictly needed at this level and if you have a CP equiped car theres easliy engough head room at this level. 100% meth on 98RON and some SSP cluch packs and you can push to max the standard turbos at 750+ whp safely. Water meth does other jobs, smoothes out throttle response and engine feel, cleans the inlet ports and pistons (these engine may suffer carbon build up - just haven't seen any examples unlike other direct injection BMW engines) plus the safe guard from knock etc. If you push your fuel demand and rely on meth with out proper control, monitoring and safety features you can melt your engine. I am at 23psi on BMS JB4 running twin #4 jets on a 50/50 mix set to flow at 12psi it runs slightly rich but as we are in our summer with temps well over 35-45'C regularly I am happy to keep the IAT and other engine temps well in check. |
01-18-2017, 04:02 AM | #3 |
Rep 188
Thanks for this, i heard once before that meth wont make much difference without a piggy or flash tune, but to me that just doesn't seem correct (not to disrespect your advise or opinion) but the simplicity of a flash cant directly impact on the boost temps being significantly reduced in both scenarios, a tune only raises the boost by a few psi and adjusts timing and fuel slightly.
The BIG difference is the boost temps reduce flashed or not |
01-18-2017, 04:49 AM | #4 |
Rep 788
BUT the S63 is so well designed and tuned it isn't pushing temps etc so its not pulling timing and has so much head room from the intercoolers, ignition and fuel system for the meth to do much if anything other than a couple of hp and smooth things, a tune and piggy pushing boost is another thing!
I would bet hard against any hp or torque benefit - note I acknowledge the other benefits of water meth... |
01-18-2017, 07:52 AM | #8 |
Rep 843
my car is getting meth kit installed right now with JB4 BCM and was told to expect around 50whp gain with 50/50. Unfortunately i don't have dyne numbers or anyway to prove it.
01-18-2017, 03:26 PM | #9 |
Rep 788
With out adding something i.e boost to increase the amount of air available, meth injection just won't do anything other than give you a rich mixture, you NEED to add a piggy or tune of some sort period.
01-18-2017, 03:50 PM | #10 |
Rep 188
Buddy, your statement just does not make sense, hate to say it but your wrong. The big picture is to ultimately cool the boost and up the octane, a tune slightly improves fuel/timing and adds another 3 psi (that's all) so why would it only produce extra power from the meth when its running an extra 3psi - lol
Standard they run roughly 20psi, tune or piggy runs 23psi the water/meth will significantly cool both scenarios causing very similar power increases for the both. Your getting confused with having a tune "specifically" for meth, which im not having as im happy to just let the ecu work out the best course of action, and dont want to tune just for meth then run dry of meth one day on full boost causing engine failure. |
01-18-2017, 06:10 PM | #11 | |
Rep 402
Dr. ///M1.50 |
01-18-2017, 06:31 PM | #12 |
Rep 188
1) It will still make extra power from the cooling, which is my original point !! its not just about the octane
2) Show me proof the injectors and fuel pump max out after a remap (this is a crazy claim) 3) We're not talking about a Civic, or just increasing octane Just FYI - The new M4 GTS just released has water injection from the factory and makes an additional 80 BHP from the cooling |
01-18-2017, 07:13 PM | #13 | |
Rep 402
2) are you kidding me?? look at a log of a non competition car at 22psi with a piggy back, the fuel trims will be maxed. Im not sure if you are new to this but but maxing the injectors is different from maxing the fuel trims. the ecu has a window of how much or how little fuel it will pump, we are maxing out that window and thats why we supplement it with meth. When you get a tune you can widen that window, thats why i specified a piggy at 22psi NOT a tune at 22psi. The hardware eventually gets maxed out as well but way more boost |
01-19-2017, 04:15 AM | #15 |
Rep 788
P.S Msizzle is spot on and repeating what I have said.
You will actual loose power by running extra rich from Meth and probably get missfires from sooting or flooding the plugs, so don't cry because we told you. |
01-19-2017, 04:27 AM | #16 | |
Rep 881
01-19-2017, 07:55 PM | #18 |
Rep 402
01-20-2017, 01:30 AM | #19 |
3387
Rep 7,542
Meth makes a huge difference particularly on tuned cars with raised boost pressure, or on consistent back to back runs without cooldown time. The higher the boost the more inconsistent the car will be run after run (act of compressing air raises temperatures, which in turn heat up the heat exchangers and rob power). Also will make a sizable difference on extended runs with long boost periods, i.e 5th and 6th gear pulls.
On the airstrip I pulled on a JB4 car w/ meth with our Stage I tune by about 1.5-2 cars. By the end of the day my car was so hot, that he took me by .5-1 car. My intake temps were through the roof, while his were kept in check w/ meth.
schnell1982345.00 |
01-20-2017, 01:53 AM | #20 |
Rep 788
Mike you are talk of extremes not normal use. Plus you won't make MORE power, you are talking about the same positives I posted ealier i.e maintaining IATs, intercooler temps and stopping ignition pulls but the ecu won't add more ignition or torque just because of adding some meth- you could very likely do all these advantages with just water.
Boost is key.... |
01-20-2017, 04:13 PM | #21 | |
3387
Rep 7,542
Tags |
methanol |
