      07-06-2015, 10:48 PM   #1
Hammer91
Drives: 2021 BMW M5 Comp
Fuel pump fuse problems
Appreciate any thoughts you guys might have on this. Dealer picked up my car for a wash, when returning it the car died pulling out of an intersection and would not restart. Had to be loaded on flatbed to get back to shop. Only fault was blown fuel pump fuse, yellow 20a in trunk box. This was replaced and car returned. First time driving died again on me pulling out of intersection. This is disconcerting because you lose steering and brake power assist when the engine dies, and it dies immediately when fuse blows. I replaced fuse myself and got car started, was able to return it to dealer. Now they are going to replace the HPFP (high pressure fuel pump), fuel filter, and fuel pump relay. My car is 2014 CP completely stock except for Dinan stage 1 piggyback. It has run like a clock with no problems until now. I never track, drag or race car.
Anyone else have or heard of this problem? I know BMW has a history of fuel pump issues. Any suggestions as to problem/solution? Thanks for any help.
      07-09-2015, 06:02 AM   #2
Lerxst M4
Lerxst M4's Avatar
Drives: F82 M4
Could actually be your fuel pump. Did you get the drivetrain malfunction alert when it died?
My low pressure fuel pump went out on mine with only 10K on the clock.
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone)
2013 F10 M5 (gone)
2008 E90 M3 (gone)
      07-24-2015, 12:47 AM   #3
Hammer91
UPDATE: Problem solved
In case someone else has this problem and finds this post on a search, thought I would update. Second time fuse blew error code for low pressure fuel pump was found. There are three fuel pumps in the M5, two are high pressure and mechanical, thus draw no electric charge and would not cause fuse to blow. Third is the sender unit in the fuel tank, it is electric and can draw enough current to cause fuse failure if malfunctioning. Dealer replaced low pressure fuel pump, fuel pump relay, and fuel filter. Problem solved, car running great.
      07-24-2015, 12:50 AM   #4
Hammer91
Turned out mine was a low pressure fuel pump as well, replaced and all good now. Never got the drivetrain malfunction alert when it died. Only 6000 miles.
