07-11-2014, 11:35 AM | #1 |
Rep 1,027
The supposed 155mph limiter
Well after making measurements with the Vbox that I bought and having a documented speed comparison at exactly 155mph, I conclude that the speed limiter doesn't limit the car to 155mph.
I posted this at the back of a thread on the mods forum but it's probably worthy of a general discussion. From what I can tell, the difference in real speed and speedo speed at 160mph is 5mph. I got this from the Vbox data which showed that the car was going exactly 155mph when I saw 160 on the HUD. This is when I slowed the car down on the dead empty completely straight road I accidentally ended up on going home on Wednesday. I made a wrong turn in a small town in west texas and took a 17 mile detour and when I discovered the mistake, the GPS showed me a road to get back on track that didn't involve retracing my steps. It turned out this road was nearly perfect for speed testing except it's not completely flat and it's not a real good road, it's a FM road in west Texas. Anyway, I hooked up the Vbox and did several quarter miles which I posted over in the mods forum. On one of them I just kept going until the road/car got a little to wiggly for me to feel good about testing the top end on the car. I was hoping to get back to 168 or 169 as I did on the way out and see what the Vbox said was the GPS measured speed. The road felt too bouncy/floaty/unstable at 160 so I shut it down. That turned out to be exactly 155 as measured by the Vbox. This along with the RPM data I observed at 168 on the way out leads me to conclude that the limiter isn't exact because my car was going probably 163 on the way out when it showed 168. I confirmed this by doing a RPM to speed calculation based on the wheel circumference of 7.06 feet and 5th gear ratio of 3.15. I also have spoken to someone who is knowledgeable of the attempts to crack the ECU on the M5 and he says that there are five things the ECU looks at to apply the limiter. So whatever they are, they don't all kick in on my car at 155. Anyone else had their car over 155 on the speedo? |
07-11-2014, 11:58 AM | #2 |
Rep 6,064
Speedos has error there is no doubt, but how much?
This has been discussed several times and for no reason I feel it must be 2-3 % (exactly like what you got 155 vs 160); however some members claim UP TO 10% !... different numbers from car to car. I saw a guy posted the dealer document that UP TO 10% + 2-3 mph is normal and they are not gonna correct it if it's in this range. I think I downloaded that letter's pic and will see if I have it at home, will post it here later... and I feel the limiter is abit more than 155 mph... BMW is generous lol
07-11-2014, 12:29 PM | #4 | |
Rep 1,027
The difference of 26.97" diameter vs. 26.72". |
07-11-2014, 12:34 PM | #5 |
Rep 2,176
My 2014 M6 CP tops out at 159 GPS but the limiter def kicked in at exactly 155 mph GPS it was just accelerating so hard it continued to 159 .
07-11-2014, 12:44 PM | #6 | |
Rep 2,176
07-11-2014, 12:58 PM | #8 |
Rep 1,027
Well that is different than mine. I definitely saw 160 and then hit the brakes on the Vbox run. The Vbox shows 155 as the max speed which would be a 3% error. You can see I hit the brakes pretty hard and I did it right at 160 because the car felt like it was sliding around.
07-11-2014, 01:00 PM | #9 | |
Rep 2,176
07-11-2014, 01:14 PM | #10 | |
Rep 1,027
I am thinking that the run in this graph will make the perfect before and after comparison for the Dinan tune. The difference will show up in the slopes of the speed graph. |
07-11-2014, 03:11 PM | #12 | |
Rep 2,674
Drives: '24 X7 M60i
Ex Stig
'25 M5 Touring (on the list, first slot) '24 X7 M60i '22 M5 CS - (sold) |
