09-24-2016, 10:06 AM | #1 |
Rep 818
Can F10 M5 LED headlight be height adjusted?
My car is lowered and i had the lights coded right when i got it so i don't exactly remember driving at night with OEM lights but it feel that the lights are not pointing enough in the distance. As if they are pointing too low.. if high beams come on then its all good, but under low beam they just don reach far enough.. has anyone experienced anything similar? Also does anyone know if there is a manual leveler for headlight beam up/down or is this all done through coding?
Thanks!! |
09-24-2016, 01:22 PM | #2 | |
Rep 1,108
09-25-2016, 03:33 AM | #3 |
Rep 788
You can do it your self.
I did mine in the garage (you can use a wall, just needs to be repeatable for distance)- headlamps on and put two pen marks on garage wall/door - open hood, lift flaps above each head lamp and turn screws (marked below) clockwise to raise (same for each side). Don't go mad, just raise 1/2" /1cm and try- road test at night and see if thats right for your drop/rake, readjust as nessacery. Just do the same number of turns for each side to keep them level. |
09-25-2016, 03:54 AM | #5 | |
Plenipotentiary
2614
Rep 3,046
As an additional note, coding to activate Glarefree/no-dazzle high beams on US F10 LED does NOT enable correct functionality. |
09-27-2016, 12:57 AM | #6 |
Rep 818
Thank you all for input!! Before I adjust anything "lemetier" i didn't understand your post; are you saying an adjustment could be made without adjusting the dial manually on each headline? I tried driving today with light stalk on for auto high beam and light switch in auto position as usual, high beam indicator came on but no high beam still pointing down and can't see jack 20ft ahead
09-27-2016, 02:21 AM | #7 | |
Plenipotentiary
2614
Rep 3,046
There is an electronic adjustment procedure to correct static the ride height point, however, coding a car in attempts to enable the Glare-free/No-Dazzle high beam Assist (which does not work) inhibits this procedure from completing due to the errors caused by invalid coding. |
11-28-2016, 04:17 PM | #8 |
Rep 818
just an update to this. I didn't get a chance to follow these instructions yet, however I was getting an alignment done the other day and the shop advised that headlight brackets were installed upside down?.. this explains why headlights were faced downward so far. They installed them in the correct position. The shop who installed my coilovers initially didnt put headlight level brackets back the proper way.
The light spread is now much better than before.. however I still think lights could be facing up more, so i'll try the manual adjustment technique mentioned in this post and advise the outcome. Honestly, when i compare my 2015 Escalade light spread to my M5 it looks like M5's headlights are turned off |
12-02-2016, 09:07 PM | #9 | |
Rep 2,135
04-02-2018, 11:09 PM | #10 | |
Rep 740
Thanks. |
04-05-2018, 03:14 PM | #11 |
Rep 818
didn't end up looking for manual adjustment and realized you cannot compare it to trucks height.. so once the brackets for headlight levelers were reversed lights were back to normal..
