      12-16-2015, 12:24 PM   #1
drbru
Drives: f10 m5
Removing the standard rear centre diffuser and replacing with challenge centre diffus
Hi all
Im hoping someone can give me some guidance in removing the standard rear centre diffuser as im hoping to install a challenge centre diffuser in its place
I understand that there are just three plastic rivet things that need to be pulled out and the rest is secured by plastic clips...
Anything else I need to know...? Does the whole diffuser need to come off or can i just remove the centre pice?
Cheers
      12-16-2015, 03:38 PM   #2
mstmng
Drives: M5 F10
Originally Posted by drbru View Post
Hi all
Cheers
you can remove just the centre piece
but i would suggest you to remove whole diffuser, as it takes extra 1 minute effort and you can get rid of a kg or so of stones stuck in your diffuser
done it many times, very quick and easy job
for diffuser you would need a screw driver or star key, cant remember now
