07-25-2021, 02:31 PM | #1 |
Rep 19,820
Interior carpet damp
If your passenger compartment rear carpet is damp then you need to duck tape up the drain slats below the windscreen if the bulkhead grommet is failing because of a blocked up drain tube and there'll be no more water ingress.
Best way to get to the grommet is from the inside pulling the thick carpet back and after removing the faulty yellow grommet gently smash the plastic water containment flat box so water can flow freely to the ground,then replace hole with new grommet adding sealer liberally around the circumference. Last edited by M5Rick; 10-21-2023 at 09:57 AM.. |
