03-22-2016, 10:33 AM | #1 |
Rep 222
M5 1/8 mile 7.61@105.39mph prep for 1/4
Figured I would post this up for additional thoughts and discussion.
Car details: Fuel: 93 mixed with E85 (10 gallons to 1) JB4/BCM - meth (50 additive) - MSR intake & charge pipes - R888's on 20inch OEM. I need more work on my 60ft as I really didn't have a clean launch and couldn't go WOT till 2nd, after that it took off and felt good. Really wanting to try for 10s this year. I had too much air in tires at 29psi, so will lower that. Also, I am still working out the bugs in my burn outs given we can't stand on the brake. Thanks as always to George at MSR for being there as a resource on every M5 topic and Terry for giving me thoughts on data logs! |
03-22-2016, 03:18 PM | #2 | |
Rep 301
03-22-2016, 03:36 PM | #3 |
Rep 222
03-22-2016, 03:44 PM | #4 |
1087
Rep 1,968
If you are 105 in the 1/8, you are very likely in the 10's... good work!
50 additive on the new firmware is what 26-27psi? That's probably 750whp and should be trapping 131-132 if conditions are good. Keep it up! |
03-22-2016, 03:53 PM | #5 |
Rep 222
50 is putting me right around 26psi peak. I was thinking about bumping up to 55 additive, but might wait for the Dodson Clutch packs to go in.
03-22-2016, 06:12 PM | #6 |
Rep 241
So other than intakes/charge pipes, your on stock turbo with stock dp, x pipe, and axel back to confirm? Nonetheless, that's a good trap speed you'll have in the 1/4 mile. Im just excited about the result with what little mods u had.
22 BMW M5 CS on order for August Production
20 BMW M5 Competition stage 1.5.... 09 Zenith R GTR CP 4.4 Stroked CP tuned..... |
03-22-2016, 06:22 PM | #7 |
1087
Rep 1,968
It should be slipping at that boost level - there is a point of diminishing returns when it comes to boost. Some of the highest dyno #'s are from 27-28psi and I am talking 800whp+
03-22-2016, 09:21 PM | #8 |
Rep 222
Correct. I have done lots of adaptation and testing lol
03-22-2016, 09:25 PM | #9 | |
Rep 222
One other note, on 100% meth. |
03-23-2016, 10:29 AM | #10 |
Rep 222
Based on discussions with George.
I will test 25psi in R888s. Burn out at least through second gear by hitting water box, WOT 1st, click quickly to second and control spin till starts sticking then let off immediately. First run I will ease into throttle to see how well it sticks, if track is prepped good and traction is there try burn out mod second pass. Same burn out, then off line hit WOT on second yellow. Car shoots up to 5krpm then takes off, hope to see it stick! If not, let off. Additional tips or thoughts? |
03-27-2016, 04:18 AM | #11 | |
Rep 1,131
Gintani Supercharger/ Gintani x-pipe/ Challenge rear muffler section powder coated black/ Alpine DCT Tune & Coding/ Republic Werkz modded headlights and tail lights/ Gloss black cosmetics, hood vents, and mirror caps/ Piano Black interior trim, Roof painted black by Ranz Motorsports/ Velos Designwerkz Solo V's/ KW V3's/ MRF Solid sub-frame bushings W/ Delrin Diff bushings/ Duke Dynamics CSL Trunk/ Euro bumper/ Full Dinmann aero kit.
03-30-2016, 08:07 AM | #12 |
Rep 222
Only got one run in and my start had serious issues. I was worried about my clutch so didn't run again. 1/8 was only 100mph and 1/4 was a laughable 12.2@134.5 as too much spinning in first half. Slowest ET I have ever ran and fastest trap at same time. Clutch packs going in today and I will try again.
03-30-2016, 01:14 PM | #13 | |
Rep 1,202
From experience (on both my supercharged E92 M3, and the F10 M5) I hate launching using the kickdown method - the car just revs and dumps the clutch. Usually without sticky tires the car will be a sitting duck lighting up the tires, but with a proper drag radial the abuse goes straight to the DCT/drivetrain. I would much prefer using LC, as it's less abusive all around than the more violent kickdown method. Looking forward to your numbers, and hearing your feedback on the Dodson clutches. |
