      09-03-2013, 07:59 AM   #1
vishwen
vishwen's Avatar
Mauritius
39
Drives: MCB M5
Increase Battery
Hey Guys,
Got an error message yesterday morning CHARGE BATTERY, then today morning i got INCREASE BATTERY CHARGE WHILE STATIONNERY.
what can cause this.
///M5 MCB (2012) TOTAL LOSS
550i M sport (2011) SOLD
545i M sport (2004) SOLD
330i M sport (2001) SOLD
      09-03-2013, 10:17 AM   #2
avlnch
Drives: 2013 Individual M5
Are you shutting your M5 down correctly?
Proper shutdown procedure:
- Engage Gear 1 or R
- Engage Parking Brake
- Press Start/Stop Button Once
If you shut the car down in N, engage the brake, and walk away from the car, th ignition will remain on. If you attempt to lock your car it will honk loudly at you. However if you park your car in a garage overnight and don't lock it, then you would not know the ignition is on unless you pay attention to the cluster after shut down.
      09-03-2013, 03:23 PM   #3
savela
savela's Avatar
Drives: 2015 X5M
This can also be coded. Press start/stop once + lock doors and it shuts things down...I think. I've had the above issue w/ my 550. They replaced a bad sensor cable...problem persisted. I don't worry about it now as the starter has never hesitated.
