06-17-2015, 08:15 AM | #1 |
Rep 643
Drives: BMW M5 F10
Garage List 2013 BMW M5 [0.00]
2011 Alpina B3S Bit ... [9.50] 2010 Alpina B3 Biturbo [10.00] 2009 Alpina B5S [10.00] |
Any member with a "30 Jahre edition" M5? We can code all of our M5s if we get info!
Hi guys
Is there anyone with the M5 "30 Jahre edition"? It has shown to deliver around 605-610WHP stock!! If we gain access to the DME information like I have gotten from a M5board member on his M5 CP we can code/flash our cars with whatever flash we want Now we are digging a bit more into the CP flash. Why stop here, the 30 jahre sounds more promising - ALSO, no hardware changes has been done from M5 to M5 CP to M5 30 jahre - A higher sounding exhaust will not gain anymore power. If anyone want to help out here let me know, PM or post! Thanks |
06-17-2015, 10:51 AM | #2 | |
Rep 6,066
06-17-2015, 11:26 AM | #3 |
Rep 643
Drives: BMW M5 F10
Because the new M6 CP will feature the same amount of HP with no HW changes. It's based on the competition package, we all know the difference is steering changes, suspension changes and the exhaust for more sounds. BMW called the "15 HP increase" a gain from higher boost.
"The foundation for these upgrades was provided by the Competition package – itself a car that already came with a power upgrade." Link: https://www.press.bmwgroup.com/unite...tem=node__4274 |
06-18-2015, 03:00 AM | #6 | |
Rep 112
2014 BMW F10 M5 LCI
06-18-2015, 04:39 AM | #7 |
Rep 102
Drives: RRS Supercharged / 991 Turbo S
I have a new CP and was just reading up about CP vs Jahre as well. It does appear there are no hardware changes at all... just 'software tuning'. But how on earth do we prize that off a BMW dealer... willingly?!
2015 White 991 Turbo S - Warp Factor 9!
2016 Yulong White Range Rover Sport 'Stealth Pack' 2015 Alpine White M5 'Competition Pack' - Gone 1971 Mercedes-Benz 280SE - Just love looking at it! 2012 Alpine White M5 - Gone |
06-18-2015, 04:44 AM | #8 |
Rep 643
Drives: BMW M5 F10
Thanks!
Qadhi79 has a access to one of these 30 jahre M5's, hopefully we will be able to gain info about the CAFD in the DMEs (ECUs). |
06-18-2015, 09:39 AM | #9 |
Rep 451
From what I've seen, the tuning changes are in the dme ecu firmware itself, not in the coded cafd.
Meaning that we can't flash cp/30 onto other vehicles. You may be able to flash the dme values but it won't have an impact, like how you can code the top speed limit higher but it won't do anything because the ecu itself is locked. Only known way of doing it is how all the flash tuners are doing it now, physical access to the dme and drill. |
06-18-2015, 10:49 AM | #10 | |
Rep 643
Drives: BMW M5 F10
Go search before posting The limiter has something to do with the DME timer, but CP can be retrofitted, if that is possible why shouldn't it be possible to attain the 30 jahre flash too? Same story, no HW changes. |
06-18-2015, 10:55 AM | #11 |
Rep 451
You're free to try. I'm aware that people have (and charge) for this type of flash, but there hasn't been any evidence of it in fact working (no dyno proving an HP change, etc.). Honestly, you're not going to tell that there's a 15 hp gain from a CP without throwing it on a dyno.
I'm just providing the information I've found while digging into this. re: DME timer, it locks down certain aspects of the DME (including top speed limit) after the vehicle has been driven a certain distance/time. From what I can tell, the CP/30 tuning params are also locked down in the same manner. Edit: See: http://f10.m5post.com/forums/attachm...3&d=1375812205 It's only top end torque/hp that's impacted, so pretty hard to tell (and small enough) that you'd really have to measure it to know if it's actually there. Last edited by v3n0m; 06-18-2015 at 11:04 AM.. |
06-18-2015, 02:22 PM | #12 | |
Rep 643
Drives: BMW M5 F10
The CP is pusing out 649HP crank and measured many times, the 30 jahre has around 605-606WHP (700HP crank). NO, it is possible in Europe to retrofit the Competition Package, if THAT is possible, it is also possible to do the 30 jahre flash Know your facts, the limiter is a different thing vs this! |
06-18-2015, 03:50 PM | #13 | ||
Rep 451
If you believe otherwise feel free to point out the actual coding params that you believe impact engine output. Not sure why you bring up crank horsepower as bmw's are known to be underrated from the factory. |
Onefastbeast0.00 |
06-18-2015, 04:09 PM | #14 |
Rep 451
I'll even kick it off. Here's my DME CAFD (non-CP).
Feel free to run it against a CP or 30 jahre, or modified CP tune DME file using ncdtool and point out what coding params are different (literally 1-click). http://www.bimmerfest.com/forums/sho...d.php?t=749668 You seem to be convinced there is a difference in these files, so I'm assuming you have at least the CP file? |
06-18-2015, 04:27 PM | #15 | |
Rep 643
Drives: BMW M5 F10
06-18-2015, 04:38 PM | #16 |
Rep 451
Yup, aware of that thread. As I mentioned in a previous post, this is a firmware flash, not coding. You don't need the ncd/cafd files as you mentioned. You need the VO and SVT of a CP/30 Jahre to figure out what you need.
Problem is (from what I've tried), is that I can't activate the FA since you need appropriate FSC codes. |
06-18-2015, 05:29 PM | #17 | |
Rep 643
Drives: BMW M5 F10
06-19-2015, 11:07 AM | #18 |
Barge driver
8647
Rep 12,421
Has any magazine figured the Jahre? IIRC Motor trend figured the M5 at launch with a 7.8 sec 0-100mph time others have been in and around that figure give or take 1/2 a second.
It's great to talk about crank or wheel HP, but the proof is in the pudding.
730d/Z4C
06-22-2015, 10:16 PM | #19 |
Rep 1,857
I have from Sport Auto, individual test.
CP Jahre 0-100km 4.2 4.1 0-160km 8.4 8.3 0-200km 12.6 12.4 80-120km 3.6/4.4/5.6/8.5 3.4/4.5/5.6/7.9 80-160km 7.2/9.3/11.5/16.4 7.2/9.2/11.5/15.9 However, there's a curveball, Sport Auto once did a comparison between the M5 CP (different car than the one above) and XFR-S, and that CP turned in: 4.1 8.2 12.3 3.4/4.3/5.4 6.9/9/11.2 Of course, weather conditions might have been slightly different, but throw in engine tolerances, there's practically no performance difference between the CP and Jahre. |
06-23-2015, 04:37 AM | #20 | |
Rep 643
Drives: BMW M5 F10
06-23-2015, 05:04 AM | #21 |
Rep 1,857
Maybe all those CP press cars have the Jahre tune, who knows. Guess it would be nice to have a private Jahre and CP data to compare, otherwise according to Sport Auto, CP cars can be faster, it was quicker around the Hockenheimring than the Jahre too, 1.13.0 to 1.13.2.
06-23-2015, 05:34 AM | #22 | |
Rep 643
Drives: BMW M5 F10
What if the 30 jahre actually has the same flash as the CP but downpipes with race cats?? Last edited by lfelunden; 06-23-2015 at 05:45 AM.. |
