      09-28-2020, 09:35 PM   #1
thxbuff2001
Dictator for Life
thxbuff2001's Avatar
Drives: To many
Clutch Delay Valve removal MT
Anyone has been able to remove the clutch delay valve on our F10 MT M5.
The switch from 1st to second is really annoying especially on slow speed/startup in SportPlus.
03 e39M5 Imola Red-Tubi Exhaust/GROMAudio
16 F10 M5JavaGrun/MT/CP/CCB/B&O/ReaRDVD
23G82M4SignalGrun/MT/CCB/CarbonBuckets
09 Ferrari SCUDERIA Rosso Corsa
23CayenneGTSCoupe
      09-29-2020, 01:23 AM   #2
Marcus Frost
Custom User Title
Drives: Various
I've done this on my F13 - I did it and also had a Rogue SSK installed, probably one of the best combinations I've done on this car besides maybe the KW H/A/S in terms of improving tangible feeling when driving the car.
You won't regret it, even if it is a bit of a pain in the ass.
2014 BMW M6 Coupe, Sakhir/Black, 6-Speed, CCB - DME/AMS/Eisenmann/Rogue/KW/MORR
2018 BMW m760i, Frozen Black/Black
2016 BMW X5 35d, Alpine White/Black, MSport
1969 Lincoln Continental Sedan
      09-29-2020, 06:48 AM   #3
Chauncey.Bishop
Big girls don't cry.
Chauncey.Bishop's Avatar
India
125
Drives: E46 M3
I believe technician117 has done this, I haven't had the chance to figure it out myself yet.
      09-29-2020, 07:00 AM   #4
thxbuff2001
Dictator for Life
Drives: To many
Do you have a link or directions? What did u use for the delay valve replacement? More info appreciated.
      09-29-2020, 09:48 PM   #5
Marcus Frost
Custom User Title
Drives: Various
I didn't do it myself, but it's pretty standard stuff. We have the same manual transmission that's on many other BMWs. You buy the modified valve, bleed the system, and install it. Install is nothing special AFAIK.
      09-29-2020, 09:51 PM   #6
thxbuff2001
Dictator for Life
Drives: To many
What valve did you use? I have time next week, I try to do it.
      09-29-2020, 09:55 PM   #7
thxbuff2001
Dictator for Life
Drives: To many
This write up perfectly explains why my e39 m5 is smoother than my f10 m5. They said bmw removed the cdv on my e39 m5 but they kept it on the regular e39.
https://www.zeckhausen.com/catalog/index.php?cPath=6562
23CayenneGTSCoupe
      09-30-2020, 06:02 AM   #8
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Correct. The E39 M5 never had a CDV unlike all other models of the time (save maybe the M3).
For the F10, spend the money on the modified valve if you like, but I just removed it and reinstalled the line. There is plenty of "length" in the hose to make up for there not being a valve in place. Bleed the line and you're GTG.
      10-01-2020, 02:59 PM   #9
Fullpoints
Drives: 2014 BMW M5 6spd CP
If someone does this, please take pictures. This seems like a mod I would like to do asap. I always thought the first gear clutch takeup seemed a bit vague, now I know why.
      10-01-2020, 05:35 PM   #10
thxbuff2001
Dictator for Life
Drives: To many
People have done it posted in youtube. I know I can do it but I dont have a high lift.
I scheduled it next week with a mechanic.
      10-01-2020, 06:47 PM   #11
Fullpoints
Thats awesome, please let us know if you feel a substantial difference next week!
      10-02-2020, 11:16 AM   #12
santamonica00
Lover of the 3rd pedal
70
Drives: '16 M5 6spd; '13 Audi S4 6 spd
In all seriousness, I just start in second all the time. Did it with my Audi S4 that I ordered new in '13 and drove the last seven years before my '16 F10 I bought at the beginning of this year. Would be interested in hearing more about this but would need to find an independent to do it. Original warranty runs out in 500 miles (or two months) and CPO is next year. Have only heard good things
      10-04-2020, 01:16 AM   #13
Marcus Frost
Custom User Title
Drives: Various
It's not just about starting in gear and slipping from a stop, it's also between shifts too. For as easy as it is, and as inexpensive, totally worth it.
      10-04-2020, 02:04 AM   #14
santamonica00
70
Assume that'll void any remaining warranty? Regardless, what does this usually cost at an independent?
      10-05-2020, 12:29 AM   #15
Marcus Frost
Custom User Title
Drives: Various
I cannot imagine anyone even knowing it's done - the way I did it, I inserted a modified valve in place of the stock one (the modified one is a BMW valve), so even a tech looking at it cannot tell the difference.
Some people remove it altogether, which also works. I don't think your warranty is in jeopardy either way, but if you want to be safe do the modified valve.
      10-05-2020, 08:09 AM   #16
Chauncey.Bishop
India
125
Drives: E46 M3
The bleed process is what's stopped me thus far. If somebody can walk me through that, I'll do the removal and document it for the rest of us.
      10-06-2020, 05:52 AM   #17
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
It's the same as any clutch slave bleeding. Reservoir is shared with the brakes. There is a bleed screw on the slave. If you're quick with the part change/part removal, not much fluid will leak anyway.
The method I've used is a "soda pop" bottle (that's been cleaned - I've been bleeding brakes with it for years) with a hose resting on the bottom and attaching to the bleeder. Keep about an inch of brake fluid in the bottom to create an air lock. Air bubbles get pushed out while bleeding but no air gets pulled back in when releasing. Open the bleeder and pump the clutch using your hand... it will probably get stuck to the floor. Repeat a bunch of times, close the bleeder, pump up the clutch pedal and check feel. Repeat 2-3 more times, keeping an eye on the reservoir level and at your bottle for fill level and also to look for air bubbles coming out. Once you don't see air, it's probably good to go. There isn't much capacity in the system, so it really shouldn't take much to bleed it out. It's just that sometimes air can get trapped because it's hard to generate pressure to move things along when the bleeder is open. A power brake bleeder probably works well here, I don't have one to try though.
      10-06-2020, 12:05 PM   #18
SGTVinny
Drives: E90
Did you end up replacing or removing it?
Also, did the clutch feel mushy or extremely soft thereafter? Does it change the clutch feel in any way?
      10-08-2020, 05:49 AM   #19
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Removed it. Clutch felt the same as usual. A delay valve does not change the characteristics of the hydraulic system in terms of feel. It just slows the movement of fluid. Pedal effort does not change.
      10-08-2020, 08:44 PM   #20
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
CDV only affects the engagement rate. It prevents "dumping the clutch".
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
M5Rick60075.00
      10-14-2020, 03:54 PM   #21
Fullpoints
Any update on this? Did you end up getting it removed? Curious to hear your impressions on if it's noticeable. Thank you!
      10-14-2020, 10:40 PM   #22
thxbuff2001
Dictator for Life
Drives: To many
Havent done it yet. Got busy with work. I plan just to do it myself next week.
