09-16-2021, 06:29 AM | #1 |
Rep 58
Blank the pcv to turbo ??
I have oil catch tanks in place. My question is why can't the pipe to the turbo be blanked of and just have the 1 pipe from the engine to the oil tank with a breather on it. ??.
Also this draws is hot air from the engine so isolate that and just have cold air entering the turbo from the filters |
09-16-2021, 10:37 AM | #2 | |
Rep 174
If you're up for it, you can try this. Only other side effect I see is causing an imbalance of the engines internal pressures. Not sure if it would be subtle or excessive, only attempting this would tell. If it is either extreme, then we all know what happens with too much or too little pressure. Do this on your own terms though if you wish, good luck. |
09-16-2021, 05:36 PM | #4 |
Rep 174
Knowing BMW that might throw off the engine pressure balance and cause some issue, but again wouldn't know unless you're willing to try this. It probably is just that simple. Most people want to stick to everything BMW does, as "there has to be a reason" but might not be the case every time. Report back any feedback if you take the plunge, I believe for most people the cans stay empty because of this loop back to the intake piping. Maybe leaving it to the can only, will cause the positive pressure to actually empty some contents into the can for a change.
carlinhos3.00 |
09-24-2021, 12:39 AM | #5 |
Rep 28
Gents,
My opinion is 'No, you shouldn't blank to PCV to turbo'. According to the S63TU engine manual, PCV hose is equipped with check valve and vent hole. When turbo is on idle, the vent hold in PCV hose prevent the vacuum pressure in crankcase doesn't go more than 100mbar. Meaning if you blank the PCV hose, there might be too much of vacuum created in crankcase. I will attach the manual if you want to see the details! |
10-07-2021, 12:35 PM | #6 | |
Rep 174
