10-16-2021, 07:37 PM | #1 |
Rep 81
Programming issues
I'm a disabled vet that was given this car. The CCC unit went bad so I replaced it because I couldn't afford to have it done by anyone else. Since I was doing the work myself I figured I would do a firmware update on all of my 2006 525XI e60 modules except for the CAS and now I'm having issues. I used K+DCAN cable & WINFPK 5.3.1. with the sp-daten ver 67.1. Everything showed that it completed "OK". Now I have all of these error codes and all kinds of issues. I need help to get back on the road. If I get this fixed I'm never touching this car ever again!!!!
SIM/SGM 93AD 60 SZL 9501 60 94C0 20 94AC 60 STVL/TEFA 963F 20 962C 60 STVR/TEBF 96FD 20 96BF 20 96AC 60 SFZ 9ABF 20 9AAC 60 DME/DDE CD99 84 CDA8 84 CD94 94 2DC3 04 CDB0 04 CDA9 14 CD9F 14 CDAB 14 CDAA 14 CDAE 14 EGS CF1B 24 CF1A 24 CF19 24 CF1E 24 CF21 34 VGSG 54C6 71 55C3 38 55D0 28 DSC D378 A4 D36A A4 D356 A4 D355 A4 5DDF A0 5EBA E0 CAS A0B1 28 KOMBI A3B3 20 A3B9 20 A3AC 20 A556 20 SBSL 984C 70 9857 70 986D 70 9878 70 9891 20 9895 60 983F 20 982C 60 SBSR 98ED 70 98F8 70 9915 60 98BF 20 98AC 60 There has been many lessons learned here. One being, I did a firmware update on all of these at one time and didn't cycle the car every time I updated the firmware. I also had a battery charger attached and NOT a voltage regulator. Lastly and most importantly, I should have had an indie shop do the work but I'm broke and now I don't have a car! Will someone please help me get out of this mess. |
10-18-2021, 01:06 PM | #2 | |
Rep 80
I once changed the center cluster unit in my Audi but all of their components have component protection on them. Any used components required to be coded / reset into virgin mode before you can sync with the gateway. Not sure if BMW has something similar Good luck |
M5Rick60075.00 |
10-19-2021, 07:24 AM | #3 | ||
Rep 81
