07-23-2018, 06:05 PM | #1 |
Rep 164
Gas tank leaking
Hi guys.
I noticed some minor gas smell and couple of drops of gas under car. Took to repair shop (not a dealer). Tech says "Fuel tank was previously damaged and a repair attempted, but is leaking again. You need a new fuel tank." Have a look at the photo. It is a close up of my F10 gas tank with the panels removed. It looks like green goop over a ground-down section. But I've owned the car since new and *I* never fixed tank. My only explanation is either (i) the tech doesn't know what he's seeing--- the green goop is from the factory and is normal-- I am just unlucky, (ii) BMW fixed this at factory or port or (iii) somebody at a shop that serviced the car took a joy ride (or lowered the car onto something while on a lift?) and secretly fixed it. None of those seem plausible. Anybody have any thoughts? Thanks in advance, Chris https://www.dropbox.com/s/vhg39smn70...6715.jpeg?dl=0 |
07-23-2018, 07:39 PM | #2 |
Rep 1,107
Definitely not normal, someone fixed that after they damaged it. Is it silicone? That sucks you can see the gouge across the front. They do sell a specific epoxy for gas tanks to fix leaks, if you want to go that route. If it was me I would fix it with either a new tank or pull the tank and have a shop fix it the right way. GL bud, that sucks though.
cnicholson16.50 |
07-24-2018, 02:06 PM | #3 |
Rep 2,350
The tank in the F10 is the 80l steel tank from the enhanced security 7 series (or something like that) and isn't the standard plastic 70l that comes on all other F10s. Hence I'd think you'd be able to weld it to repair it.
cnicholson16.50 |
07-25-2018, 12:01 PM | #4 |
Rep 1,124
I wouldn't screw around with repair attempts. Replace the tank...I know it hurts, but it's better in the end. Gas tank is around $1400 which is expensive. Welding is only plausible with a professional that knows the dangers of welding with fumes! If you find someone willing, it'll save you a bit.
Aside of the two choices above, everything else is crap....epoxies, goops=crap! Picture looks like they left one of the lift 'legs' under the car, then noticed while backing out |
07-25-2018, 12:09 PM | #5 |
Rep 164
