09-02-2017, 09:33 PM | #1 |
Rep 8,339
Which exhaust gives the best power increases?
Looking at all the different exhausts out there, which ones have given the best power increases? Is full exhaust the way to go? Axle back like turner eliminate the choke points? Going to have catless downpipes, want to minimize drone and not break the bank. Priorities in order are power increase, price, drone elimination, sound, looks, weight savings. Thx.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
09-02-2017, 10:45 PM | #2 |
1087
Rep 1,968
Remove the cats and stick to stock.... want looks add the M Performance tips
09-03-2017, 04:30 PM | #3 |
Rep 2,039
Downpipes (for mid range power) and axle back (for tone, volume, pitch). Mid pipe and oem resonators are fine and don't need to be changed.
alienstudio30.00 |
09-03-2017, 06:31 PM | #5 |
Rep 5,231
Catless DP and stock exhaust is a good starting point IMO; you can always move on to something else if it doesn't provide what you're looking for. Catless DP's will free up some HP but little gains in terms of HP regardless of the exhaust.
09-03-2017, 07:20 PM | #6 |
Rep 8,339
From what i was hearing the stock exhaust x pipe is restrictive. If you make or install a larger one it frees up the flow. I'm already planning catless DO and at least axle back but was wondering if the full exhaust kits had better flow than the one, especially in the xpipe area.
12-13-2017, 12:00 PM | #7 |
Rep 207
for max gain, would be a catless downpipe, but some people dont want to go the catless route. if keeping the downpipes and doing the downpipes back, the RPi GTM gives a 15 to 20 HP gain
