      11-12-2020, 09:36 AM   #1
Fast.F10
Extruding Elements
Fast.F10's Avatar
Drives: 2016 BMW M5 Comp
2016 BMW M5 F10  [0.00]
Super Sport on front and PS4 on rear
The time has come for new rear tires for some odd reason , fronts still have good life on them. Is it ok (no weird ill effects: noise or other) to run SS in front and PS4 in the rear? Sticking with the OEM spec but also want to add on some spacers down the road; assuming 5mm in the front and 10mm in the rear will be proper?
Sorry, tire noob; much thanks
2022 Yukon XL AT4
2016 BMW M5
2015 Ford F250 Super Duty
2006 BMW M5
      11-12-2020, 12:04 PM   #2
vafan13
Drives: Sakhir Orange F10 M5
Off a track I can't imagine it being of any concern. Probably push you a bit more into understeer by way of the rear getting more grip than what you're replacing, but can't imagine that being noticeable on the road (at least not in a bad way).
I remember reading that at least some folks had bad experiences with the 10mm spacers specifically and there were suggestions to go lower or higher. Personally I'm considering 12s all around.
Fast.F10513.50
