      05-05-2019, 03:33 PM   #1
His4
His4's Avatar
39
Drives: F13 M6
bootmod log - misfire
hey there,
Noob question:
I try to understand a log.
can someone please explain me how to understand a log.
today i got in every run misfires and i want to see why and whats wrong.
http://www.bootmod3.net/log?id=5ccf09cac090c64dbb3d00e8
Where i can see timing in zylinder 8 ?
thanks for help !!
      05-06-2019, 09:18 AM   #2
carlitosgomesm5
Originally Posted by His4 View Post
hey there,
Noob question:
http://www.bootmod3.net/www/index.ht...5#/drawer/logs
thanks for help !!
i cant see your log for some reason however how many miles do your spark plugs have? What tune are you running? I had drivetrain errors on a stage 1 oct93 beta which cause the car to lose power, went back to stock and no issues. I am changing my spark plugs to NGK and gapping them. Then trying again. But my car is at 70k miles and possibly havent had the sparks changed and this is known to cause misfires. A bad tune can also cause knocks if pushing the engine hard. Just my two cents. I am also a new BM3 user. You can also reach out to their support.
      05-06-2019, 09:22 AM   #3
His4
His4's Avatar
39
Drives: F13 M6
hi,
i changed all NGK spark plugs to .022" gap and all coils.
check now the Link:
      05-06-2019, 09:31 AM   #4
carlitosgomesm5
hi,
check now the Link:
Did you check BM3 to see if it shows any errors? What happens if you go back to stock does it misfire?
I am unsure myself how to read the logs so can't help you much, it does seem though that there was 1 knock and that is usually not good but i don't know how common those are sorry. You could try and open a support ticket too. What OST map are you running?
      05-06-2019, 09:33 AM   #5
His4
His4's Avatar
39
Drives: F13 M6
i run custom map HCP Stage 2+
ye i will open a support ticket
      05-06-2019, 09:37 AM   #6
carlitosgomesm5
Cool, if its a custom HCP map you could reach out to HCP i would assume that they would be able to help. You could also load a different stage 2 tune and see if the same misfires are happening, if not it could be the tune.
      05-06-2019, 09:39 AM   #7
His4
His4's Avatar
39
Drives: F13 M6
Thanks for ypur input.
I tryed other maps. But the issues is still there.
Maybe someone can see the problem in the log.
Do you know, where i can see the timing for zylinder 8 ?
      05-06-2019, 09:42 AM   #8
carlitosgomesm5
Sorry no idea but if that is happening to every map you tried then it could be an issue with cylynder 8, perhaps bad spark plug. Does the BM3 show you any error codes?
      05-06-2019, 09:43 AM   #9
His4
His4's Avatar
39
Drives: F13 M6
Yes show misfire on zylinder 8. i changed plugs an coils.
But problem stil there. Hmm :-/
      05-06-2019, 09:48 AM   #10
carlitosgomesm5
Maybe the sparkplug has gone bad or the coil. maybe take it out and try to reinstall? Did you apply some anti-seize to the spark plugs or did they already have that? Check this link and see if you need anti-seize?
http://ricksfreeautorepairadvice.com...-plug-threads/
      05-06-2019, 09:58 AM   #11
His4
His4's Avatar
39
Drives: F13 M6
I changed plug and coil with zylinder 5. but the issue stays in zylinder 8
      05-06-2019, 10:01 AM   #12
carlitosgomesm5
Does this also happen when running stock map?
      05-06-2019, 11:11 AM   #13
Pikey Motorsports
Pikey Motorsports's Avatar
Drives: M5
Injector? And what fuel Aral?
      05-06-2019, 11:33 AM   #14
His4
His4's Avatar
39
Drives: F13 M6
I changed all injektors and coded them with insta.
Only 102 Aral Ultimate
      05-06-2019, 02:29 PM   #15
Pikey Motorsports
Drives: M5
Do you have any logs without misfire of this tune
      05-06-2019, 02:30 PM   #16
carlitosgomesm5
I think if you go back to stock and the issues persist you need to go and see BMW or someone to check your engine and see whats up with cylinder 8.
      05-06-2019, 02:33 PM   #17
His4
His4's Avatar
39
Drives: F13 M6
yes, here:
1. run
http://www.bootmod3.net/log?id=5ccefa48c090c64dbb3d009a
2. run
http://www.bootmod3.net/log?id=5ccefc5ec090c64dbb3d00b3
3. run
http://www.bootmod3.net/log?id=5ccefc12c090c64dbb3d00ac
      05-06-2019, 04:55 PM   #18
Pikey Motorsports
Drives: M5
Send them to halim to check you are getting some knocks
      05-06-2019, 07:55 PM   #19
carlitosgomesm5
I agree it is odd that is getting misfires with other tunes as well.
